Retrofitting Dynamic Indicators
Kfav82
17
Das und Pinbelegung prüfen?
Ich habe das hier gerade auf AliExpress gefunden:
58,03 € | Auto Blinker dynamische Anzeige LED Rücklicht Zusatzmodul Kabel Kabelbaum Rücklichtmodul für Porsche Cayenne 2016-2018
I guess the only way to check is to view a wiring diagram for the Cayenne as it doesn't show in the listing.
cairus
1,576
552
In principle, it doesn't matter how the Porsche is connected. You just have to pin the pins according to the KL assignment.
Kfav82
17
I wasn't happy as due to covid shortages they were missing from my recently purchased Leon FR, but I have finally found a solution to 'retrofit' dynamic style rear indicators at a relatively low cost that's plug and play with no cutting of any wires, etc at all.
Working with someone who sells plug in modules for other VAG cars, using factory wiring diagrams and genuine plugs he has been able to produce a set for the MK4.
He'll be able to produce some more if there's interest, I am not sure about forum rules for posting this sort of thing though?
I am trying to upload a video showing the module fitted to the right hand side.
Reactions: cairus
Kfav82
17
I gave up trying to upload a video as it doesn't work so have attempted to make a youtube short instead 🤣
Reactions: cairus
Kfav82
17
Anyone resolved this? Because i also have the same problem, i want to install the full led rear lights with dynamic indicators
To install the correct LED lamps, the wiring and coding would cost an absolute fortune so I have settled for fitting these modules that give a dynamic effect indicator. They are plug and play, so no cutting any wires and can be removed if you don't like them.
