Loads of stuff here: http://www.seatcupra.net/forums/showthread.php?t=395255&highlight=led+bulb
In the end I got this for my reverse light (2016 Leon SC (Estate)):
http://www.autobulbsdirect.co.uk/382-Twenty20-Cree-LED-12V-P21W-Canbus-Bayonet-Bulb.html
It works and is brighter
There's another thread on here somewhere that confirms the bulb type, can't remember what it is off the top of my head but it's definitely on my to do listdefo for upgrading the reversing lamp - too much like a candle - did my 1.2TSI last year, can't remember which ebay seller it was but no probs and it worked fine, but had to buy 2 leds bulbs. Both are spare now I've a facelift Cupra 300, which has led bulbs except the reversing which is some sort of stupid wedge thing! :-(
I've just had a pair of osram replacement led bulbs for my facelift fr arrive. Here's the eBay item number 352022351313. Bought these on the recommendation of another member on here from another thread a while back. Not fitted yet as only arrived today though.Any ideas for a facelift Cupra? - LED bulbs all round except reverse which is just as poor as my original mk 3 leon. And annoyingly a different size so I can't even reuse the led bulb I bought over a year ago![]()
Hi can you do a before and after picture of your install to show how much of a brightness change I can expectI've just had a pair of osram replacement led bulbs for my facelift fr arrive. Here's the eBay item number 352022351313. Bought these on the recommendation of another member on here from another thread a while back. Not fitted yet as only arrived today though.
Sent from my SM-G930F using Tapatalk
I can yeah. Hopefully I can get it done tomorrow if I get time, if not Monday probably.Hi can you do a before and after picture of your install to show how much of a brightness change I can expect
Sent from my SM-G950F using Tapatalk
Here are before and after pics. Brightness isn't overly noticeable from inside the car but I was on a lit road. Does look visually brighter from outside but I changed it just so that it was led like the rest.Hi can you do a before and after picture of your install to show how much of a brightness change I can expect
One note to add is that, like my pre facelift, it does seem to interfere with the dab signal when you select reverse??? Was hoping this wouldn't be the case but apparently it is.
