Reverse camera calibration values - Leon ST estate 2019 facelift
LeylandVCDS
559
340
Leyland, Lancashire
As per title, does anyone have the calibration values for calibrating the reverse camera on the ST facelift?
Got both OBDeleven and VCP, just need the values to input and finally clear the "basic settings not carried out" fault code - all working absolutely perfectly, just this recurring fault code.
Cannot calibrate the system as All the measurements are at present blank
Many thanks
LeylandVCDS
559
340
Leyland, Lancashire
You cannot calibrate it properly without using incorrect values, as the high line camera was never offered from the factory for the mk3 Leon
This means there isn’t a suitable dataset available that will accept the measured values
So is there any dataset available that would just clear the no basic settings error on scans? Does changing values actually alter the camera image on screen?
LeylandVCDS
559
340
Leyland, Lancashire
You can use an incorrect dataset with the wrong values to clear the errors
Yes the image usually changes after calibration, however in this case due to the values used it'll never be anywhere near accurate.
End of the day I don't use the lines on screen, just the image - tried a set of values from Octavia 3 as found in a Golf 7.5 forum, but VCP won't calibrate because of a malfunction error - but no issues seen in the working of the camera. Can you suggest what might be wrong? No other DTCs anywhere in the car except for the reverse camera no basic settings. Thanks
