revo and egr valve
hoggy a
Newbie
Mar 24, 2005
92
can revo block the egr valve from coming on if you get one of there re-maps,been told it just needs programming when they up load the map onto your car,or do i need to blank it off then get the re-map
hoggy a
Newbie
Mar 24, 2005
92
got told by a vag tech today the ecu looks for the egr valve, so if it can be removed by revo then the ecu does not look for it making it not work and putting a light on your dash
FR_MATT
1,388
You can:
1. remove the EGR completely and replace with a delete kit, this will bring on the engine warning light that can be mapped out. Depending on which kit you get it also removes the ASV(anti stutter valve) which some people aren't keen to do just in case the worst happens and the engine won't turn off.
2. blank or reduce with gaskets, the blank brings on the warning lights the reducers don't usually
3. turn down the settings with VAGCOM to limit it's use
4. do a combination of 2. and 3. to physically and electronically reduce it :)
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
so the answer to my question is,do i need to blank it off or can revo do it ????
Tuners usually (most of them) turn the duty cycle right down as a matter of course on these diesels, so yes, revo can do that. The ECU doesn't exactly look for the EGR, but monitors the airflow. If the EGR is removed, the airflow changes.
hoggy a
Newbie
Mar 24, 2005
92
so is it best to remove the egr or just get revo to map it out,or do i need a blanking kit,i was told revo could re-map it out saving me buying a blanking kit,this is getting confusing
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
Revo can turn the duty cycle right down, but to totally stop it, either remove it or blank it off. Personally I wouldn't, most people on here focus on the cons and forget the pros of the EGR, but thats just my humble opinion.
hoggy a
Newbie
Mar 24, 2005
92
so really clean it out or put a new one on would be your advice
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
It's a very debateable topic regarding the EGR. It plays a big part in the engine running correctly especially in winter and cold climates, and not only there for emissions, but as previously stated, there are pros and cons, and many would argue more cons. Do what you think is best.
hoggy a
Newbie
Mar 24, 2005
92
It's a very debateable topic regarding the EGR. It plays a big part in the engine running correctly especially in winter and cold climates, and not only there for emissions, but as preveviously stated, there are pros and cons, and many would argue more cons. Do what you think is best.
ummmmmm think ill clean it out and then look at anew one if i get a problem,any ideas how easy it is to remove
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
It's relatively straight forward. Remove boost bipe, 3 X allen bolts holding it to the air intake manifold, a 2 X connecting the EGR to the pipes going to the turbo. Access to the bolts is the difficult part, but doable.
Most people just remove it or block it off, it does promote faster spool up etc
