When did you get stage 2 mart? Before or after me? I've had mine since about year last september ish, maybe earlier coz that looks way different to mine.
I was on Stage 1.5 for a while...then I had it re-flashed by JKM with Stage 2 AA code (rather than AB which was coded for the R). I'm not sure how old that log is though...
I had stage 2 from the start....I never ran the car on Stage 1.
Worth a go phil, Im yet to get my car back and log with the new code installed ive also added the 'race' N75 valve aswell. but as soon as shes back ill get it logged if you havent done before hand.
When i went to the JKM RR day a couple of momths ago alot of the LCR lads on stg2 were only pulling 240bhp or there abouts there was a debate going on weather it could be the map or not and apprently some of the skoda boys had problems? If there could be a incline that there could be somthing wrong with the map, im more than happy to book a day off (as soon as i get the car back) and take a trip upto Revo HQ with my recent logs for them to have a look as there only about 40mins from me.
Its a bad situation when both of us have ran a stg1 with a k03 and pulled mid 220`s then install a bigger turbo with a stg2 map and get lower results.
My RR result doesnt concern me to be honest as something was up with it on the rollers, but i'm just thining it might be the map as the requested is so much lower than the actual when it had the problem it might just be the ecu regulating the boost.
It would be great if you could log it when you get the car back and post up to see if its any different from what we're seeing.
FYI
My 227bhp was on stage 2 running HB8 T8 iirc on a k03 btw.
I had 210bhp on stage 1 and k03.
I certinatly will, with abit of luck should be by the end of the week, but ive been saying that for the past 3 weeks:blink:.
Sorry i wasnt aware that your 227 was on a stg2, My 224 was on a k03 stg1 but i think the rollers were a tad optimistic :D
Lol @ daz, old school. I;ll give grant a buzz tomorrow to see what the score is.
Be nice if revo kev could chip in on this as well.
yea soz was going to get some up but havin problems miss firing and banging on full load heres a really quick one in second if it helps you at all?
Code:
'115				Group C:
RPM	Load	Absolute Pres.	Absolute Pres.
				TIME
 /min	%	 mbar	 mbar	STAMP
1240	59.4	1000	1030
1520	89.5	1540	1130
2000	115	2040	1370
2640	165.4	2190	1940
3080	189.5	2190	2420
3480	188.7	2170	2340
3920	185	2170	2260
4520	178.2	2140	2180
5000	173.7	2140	2050
5320	167.7	2100	2040
5600	158.6	2060	2000
5880	151.9	2000	1920
Heres one of mine Phil set at B9T9. Requested looks pretty similar to all the boys on stage 2. Although i've had to crank my wastegate a fair bit to get the actual to peak around 22psi and follow the requested.
Ever since i had the stage 2 upgrade my car seemed to under-perform and always wondered if there was an newer update available.
Code:
'115				Group C:	 Not Running
				TIME
2240	94.7	2130	1170
2440	120.3	2190	1530
2680	142.9	2210	1860
2920	163.2	2220	2140
3200	187.2	2220	2420
3480	191.7	2200	2490
3800	188	2200	2470
4040	189.5	2210	2430
4320	187.2	2190	2400
4560	182.7	2150	2330
4800	179.7	2150	2240
5000	174.4	2130	2160
5200	169.9	2100	2110
5400	163.2	2080	2080
5600	157.9	2050	2070
5720	154.9	2030	2040
5840	153.4	2010	1990
6000	151.1	1990	1960
6120	148.1	1960	1950
6200	147.4	1940	1940
Strange isnt it that stage 2 requests quite a bit lower than stage 1 which isnt supposed to have as many supporting mods.
I'll post up if there might be an update for me as i had mine done a while ago.
DPJ's log is asking for 2120 @ 6240, where ours is asking that at 5000!
Yeah it is a bit strange. Maybe its just because its a smoother more progressive map. Although what turbo is DPJ's stage 2 mapped for? ko3s or ko4? Stage 2 on the Ibiza is written for the ko3 isn't so presumably they limit requested at higher as a safeguard. I haven't got any logs of stage 1 at b9t9 to compare unfortunately.
Keep us posted about the update though.
I think you've missed the point a little, stage 1 ibiza map is showing the boost to be more agressive even on lower settings than stage 2
Stage 2 does request more boost further up the rev range as far as i can see, but not much and this might even disappear if stage 1 was logged on HB9.
DPJ's map is for a k03s stage 2 leon.
Sorry i meant ours will be requesting less than DPJ's as the software was written for different turbo's. But yeah to say our stage 2's are maxed out the requested is definitely a bit low in comparison to stage 1. Its a shame they don't do a code for the ko3's ibiza's now there's more around.
Maybe you should get onto Revo and let them use yours as a tester car Phil ;):lol:
You'll probably find that it depends on which stg1 file you're comparing to, in the early days there was no stg2 code and 'Revo' code had a much wider range of adjustment then to account for differences between completely stock and what we'd call 'stage2' spec cars. However back then the levels of adjustment were way too much and you could really get into trouble with higher settings. All we did was spend every minute god gives on the phone to customers that had put settings too high and their cars weren't running right.
Then stg1 and stg2 were released, this gave different levels of adjustment within the two maps. Stg2 has to cater for a vast range of cars: from one with a full exhaust/intake/fpr to those with that plus hoses/FMIC/etc/etc/etc. The difference between the stock (dogsh*t) IC and a decent FMIC is so much that the settings you run would be vastly different. Boost isn't the be all end all, if you are running a different turbo than stock and want more than stg2 offers then put an MBC on. You can request what you want then and for a K03s the fuelling is more than enough. There's lots of adjustment there, you can't compare settings between stg1 and 2 codes due to differences in tuning, it's a struggle to compare cars due to adapation variances as well. I don't see any load being monitored, thus can't see if the ECU is having to pull back either!
Hope this helps.
Kev, would you be prepared to post some instruction on monitoring load and interpreting the results? (In the Vag-Com section) :)
I would be interested in this too as I'm convinced myself and others do not load the car up properly when logging and adjusting SPS settings. Thus making for what can be interesting dyno results due to not enough or too much load by the dyno operator.
