I wonder what the difference is![]()
the springs on the front have to be stronger/stiffer to support the extra weight of the heavier/bigger engines. Not sure if the front shocks are different though..
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
That hole under the scuttle panel looks like the one that caused mine to leak water in!
Mine did have a bung, however it didn't seem to be fitted properly and wasn't sealed, so a big blob of water resistant silicone later, the car hasn't let water in again since.
a sig for you
What difference does it make though, a fraduster could see it on my drive and clone the plates?
Difference is some one local most likely won't clone it! National Ayee
Which makes the least sense. If someone local cloned my plate, I might get confused and pay there speeding fine.
If someone in London does it, I'll be pretty sure it wasn't me![]()
good job there, see my RRide for my attempt. really couldn't be arsed doing it again lol
i think a black S looks alot better than a badge less grill
Ok today i was off work so decided to clean the under the wheel archs. Took me bloody ages and still got one to do, 6.5 hours all in so far! Here is what my rear wheel arch looks like now
Definatley the worst cleaning job on the car, fingers are sore from all the scrubbing!
Looking good. What did you use for cleaning them? Hope you put some protection on when you were done to make it easy next time
