Are you sure you haven't got the N75 wiring rubbing on something, Rob? Short to ground sounds like what it says...........
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
I understood that you wanted it just in front of the TB for maximum Timing effect, and just after the intercooler for maximum cooling effect.
In reality, it'll be a compromise on where it'll fit, wiring and plumbing etc, and where Dave's fitted his!
100% agreeLooks good Rob but a little concerned that the 'C' section beam your using is not in its correct orientation. This will be very very strong but with a very small amount of metal facing the front of the car. The OEM bar has strength in the correct direction.
I do think your bar will be stiffer than the OEM one but not too sure its totally correct
