Status
Not open for further replies.
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Glad you got her sorted fella, bet it was a bit of a brown trousers moment when she wouldnt work. What acuator are you running as i have a spare forge one if you need it?
wild willy
2,323
Wales
You know what Rob, thats a really good quality pic there mate nice depth of view and good focus on the principle target. What camera is it.
RobDon
Pro Detailer
It's a Casio Exilim EX-Z750 7.2 mpixel camera. Read loads of reviews before buying it, it's a really good camera.
I used the Devils Own fitting to mount the nozzle in the hose as it's alot better than the Revotec one I had in there, luckily the hole was the right size!
RobDon
Pro Detailer
Ok pump is mounted in the boot, I have decided to use the washer tank due to the low mileage I do it doesn't warrant a second tank, so using the DO supplied fitting, I tapped into the tank and fitted it, hose is run down to the pump and hose run from the pump to the nozzle at the front of the car. I also re-instated the level indicator in the washer tank to warn me of low water/methanol, I had to run wiring right from the front of the car to the boot, but it's done. All that's left to do is wire up the DO controller and it's finished.
Some of the new battery stuff arrived today but still waiting on the new heavy duty cable.
RobDon
Pro Detailer
Got the rest of the battery stuff later today, so set about ripping out all the old battery cables and installing the new heavier duty stuff. All the connectors are properly crimped on and heatshrunk, so a vastly improved install over the old one.
New junction box in the engine bay:
http://i312.photobucket.com/albums/ll330/SonicBlueLeon/batt1.jpg
New cable down to the starter motor:
http://i312.photobucket.com/albums/ll330/SonicBlueLeon/batt2.jpg
Pics in the boot soon, new battery is fitted too.
xnox202
1M ST-TLD
Apr 15, 2008
182
Brunei Darussalam
So let me get this straight, it's only ideal when full-throttled (which of course increases the power)? The injection should be controlled via something right?
RobDon
Pro Detailer
Devils own WMI install is finished! Got everything wired up and all the trim back in. Car started no problem tonight so all my new battery cables are working well.
Reports on running soon, hopefully the boost is fixed too after sorting the actuator arm out too.
Status
