Well it’s down on power and a 29.4bhp increase is not great 250+ was hoping for from the stage one and the little extra stuff on the car but driving it you would not have guessed it does pick up real well
Assuming 210bhp to start with, we are looking at 16% losses. Which would mean you have 246bhp now - a 36bhp increase.
To be honest, I'd say if it drives as well as you say (and I believe that it does) then just use the rolling road figures as proof of the increase that you've gained.
You've got a 17% increase over stock, which would take a LCR 210 to 246bhp. There are so many variables with a RR, they really can only be used to test improvements made in your vehicle, rather than comparing to factory figures. Without knowing how other LCRs have done on the dyno on the same day I really wouldn't worry. And if you never had a remap you'd still believe you had a 210bhp car, so enjoy the 246bhp I say!
Dyno Lottery
AFR wise confirm the car with logging cars lambda value under same gear/acceleration run
lean is usually maf demise
Am I slow here, how do I have a 246bhp when I first got the car it was 207bhp at best and now “236 bhp” that’s only a extra 29bhp…. Or am I retarded lol
Heh no worries, I am simply assuming that your car was a known 210bhp when it went on the rolling road and got 176bhp at the wheels - a 16% loss.
Now, if you extrapolate that back up from your new 207bhp at the wheels - you get 246bhp at the fly!
Try it and see: 210x0.84=176 and 246x0.84=207
I have played with over 12 rolling roads across the UK and I have found to take fly wheel HP with a pinch of salt. One DD dyno gave a 164 wbhp and 205bhp at the fly, if we are working on 15% lossess then the fly bhp should have been close on 190bhp?? Then another DD rolling road and another car gave 187wbhp and 217bhp at the fly? Using the maths from the 1st DD dyno of whbhp / 0.8 = fbhp then the 187whbhp should have made 233bhp at the fly not 217bhp? Both dynos ran in shoot out mode and the cars both Golf mk4 AUM 5 speed.
The rolling road I use will give the same wbhp time after time, but the coastdown can vary up to 8bhp on the same car
We need to be looking at the wheel bhp and the exact wheel bhp gains, plus we need to take in to account the correction factor one correction will give a uncorrected 200bhp wbhp 202wbhp corrected and another factor could give 206bhp corrected.
I found the following links which are really helps getting your head around this dyno stuff.
http://www.pumaracing.co.uk/coastdwn.htm
I can comfirm the gear cost down in 3rd, 4th 5th & 6th can differ from 19bhp in 3rd gear to 43bhp in 6th gear. The power run in 5th gave the most realistic coast down result on a stock Leon 150pd.
An few more links
http://www.pumaracing.co.uk/trans.htm
http://www.pumaracing.co.uk/POWER3.htm
http://www.pumaracing.co.uk/setup01.htm
Not my write ups, just wish I could do a write up like them but I am crap at putting what I know in to text, I was gifted with a good gob..lol
And a really good write up from JKM http://www.jkm.org.uk/performance/dynotesting.htm
Ben
well i ran mines on a dastec roller an i got bhp=251.5 torque=240.9 (cc) and they says mine was running lean aswell:shrug:
Ok, this thread came about from Richard's car having a RR run and the operator said it was running dangerously lean. Following that, I logged the car and my logs confirm the lean running.
Code:
Wednesday	22	July	2009	18:39:01
1ML 906 032 		1.8l R4/5VT         0001
'003				'020
RPM	Mass Flow	Load	Ign. Timing	Idle Stabilization
 /min	 g/s	%	 °BTDC	 CF	 CF	 CF	 CF
2640	88.19	96.5	8.3	0	0	0	0
2880	100.53	99.2	3.8	0	0	0	0
3160	110.06	100	9.8	0	0	0	0
3400	119.03	100	10.5	0	0	0	0
3640	121.89	100	12	0	0	0	3
3880	135.28	100	12.8	0	0	0	3
4160	147	100	13.5	0	0	0	2.3
4360	155.81	100	12	0	0	3	2.3
4600	164.11	100	12	0	0	3	1.5
4840	169.44	100	7.5	3	3	6	4.5
5040	178.75	100	8.3	6	6	6	4.5
5200	181.22	100	5.3	6	6	5.3	7.5
5360	186.47	100	9	6	9	8.3	7.5
5560	189.08	100	8.3	5.3	9	8.3	7.5
5720	183.97	100	10.5	5.3	8.3	7.5	6.8
5880	184.83	100	11.3	4.5	8.3	7.5	6.8
6000	182.14	100	12	7.5	7.5	6.8	6
6160	186.64	100	15	7.5	7.5	6.8	6
5400	5.78	8.6	4.5	6.8	7.5	6.8	6
5000	196.75	96.9	10.5	4.5	5.3	4.5	3.8
5080	181.83	100	5.3	7.5	7.5	7.5	6
5040	6.69	8.2	5.3	0	0	0	0
Code:
Wednesday	22	July	2009	18:42:29
'115				'031
RPM	Load	Absolute Pres.	Absolute Pres.	Lambda Factor	Lambda Factor
 /min	%	 mbar	 mbar
2360	106.8	1680	1280	0.938	1
2560	136.1	1740	1660	1.008	1
2800	178.9	2160	2240	0.953	0.953
3080	182	2180	2190	0.953	0.953
3280	182	2210	2220	0.945	0.953
3600	182	2250	2180	0.945	0.953
3840	191	2250	2310	0.922	0.953
4040	184.2	2260	2250	0.914	0.922
4280	186.5	2250	2230	0.821	0.828
4520	182.7	2240	2220	0.75	0.766
4760	180.5	2230	2210	0.75	0.774
4960	182.7	2230	2210	0.828	0.828
5200	181.2	2210	2190	0.852	0.852
5400	178.2	2190	2190	0.75	0.727
5560	180.5	2170	2160	0.75	0.672
5720	177.4	2150	2130	0.75	0.719
5880	171.4	2110	2140	0.75	0.758
6000	172.9	2090	2090	0.75	0.782
6120	175.2	2100	2020	0.75	0.727
6280	166.9	2100	2050	0.75	0.68
6400	152.6	2080	2150	0.75	0.696
6520	163.9	2070	2100	0.75	0.704
6680	139.8	2050	2090	0.75	0.696
6760	162.4	2050	2000	0.75	0.688
6880	138.3	2020	2010	0.75	0.688
6840	80.5	970	1870	0.766	0.696
Code:
Wednesday	22	July	2009	18:45:31
'118				'032
RPM	Temperature	Load	Absolute Pres.	Lambda	Lambda
 /min	°C	%	 mbar	%	%
2760	30	0	990	-0.2	-7.8
2800	30	57.6	1170	-0.2	-7.8
3000	30	88.6	1900	-0.2	-7.8
3240	29	78	2280	-0.2	-7.8
3520	29	79.2	2230	-0.2	-7.8
3800	29	79.2	2220	-0.2	-7.8
4040	30	78.8	2240	-0.2	-7.8
4280	31	78.8	2260	-0.2	-7.8
4480	32	79.2	2240	-0.2	-7.8
4720	33	79.6	2210	-0.2	-7.8
4920	35	80.4	2230	-0.2	-7.8
5120	36	80.8	2250	-0.2	-7.8
5320	39	83.1	2190	-0.2	-7.8
5520	39	84.3	2170	-0.2	-7.8
5720	42	83.9	2140	-0.2	-7.8
5880	45	83.1	2080	-0.2	-7.8
6040	46	80.8	2120	-0.2	-7.8
6200	48	82.7	2040	-0.2	-7.8
6280	49	81.6	2160	-0.2	-7.8
6440	50	82.4	2120	-0.2	-7.8
6560	51	82.4	2100	-0.2	-7.8
6720	52	79.2	2070	-0.2	-7.8
6760	54	81.6	2100	-0.2	-7.8
Richard went back to the tuner, who adjusted the map. Due to water pump failure, we haven't had a chance to relog the car until tonight. Here are the results...
Code:
Wednesday	19	August	2009	18:07:59
'003				'020
RPM	Mass Flow	Load	Ign. Timing	Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
2120	47.56	87.8	12	0	0	0	0
2320	61.36	91.8	9	0	3	0	0
2520	83.39	95.3	3	0	3	0	0
2760	107.97	97.6	3.8	0	2.3	0	0
3040	101.86	100	7.5	0	2.3	0	0
3320	106.72	100	7.5	0	1.5	0	0
3560	121.75	100	11.3	0	1.5	0	0
3800	122	100	12	0	0.8	0	0
4040	137.25	100	12.8	0	0.8	3	3
4240	148.81	100	9	3	0	3	3
4440	158.44	100	8.3	3	3	2.3	3
4640	159.56	100	7.5	3	3	2.3	2.3
4840	171.56	100	9	5.3	2.3	5.3	2.3
5080	179.44	100	9	5.3	2.3	5.3	5.3
5280	184.19	100	7.5	5.3	5.3	4.5	5.3
5400	186.97	100	3.8	7.5	5.3	7.5	7.5
5600	185.42	100	7.5	7.5	7.5	7.5	7.5
5760	182.75	100	9.8	7.5	7.5	6.8	10.5
5960	183.64	100	12	6.8	10.5	9.8	10.5
6080	182.44	100	12.8	6.8	10.5	9.8	9.8
6200	184.53	99.6	11.3	6	9.8	9	9.8
6320	188.47	100	8.3	6	9.8	9	9
6440	186.89	99.6	10.5	5.3	9.8	8.3	8.3
6560	187.56	100	12	5.3	9	8.3	8.3
6640	186.64	99.2	12	5.3	9	8.3	7.5
6760	188.78	99.6	12	4.5	8.3	7.5	7.5
Code:
'115				'031
 /min	%	 mbar	 mbar
2080	104.5	1910	1380	0.977	1
2240	118	2110	1530	0.977	0.969
2440	145.9	2180	1850	0.961	0.953
2680	178.2	2160	2290	0.945	0.953
2960	174.4	2120	2190	0.961	0.953
3200	171.4	2130	2150	0.945	0.953
3440	171.4	2150	2140	0.938	0.953
3640	175.2	2180	2170	0.945	0.953
3920	172.9	2210	2190	0.953	0.953
4120	172.9	2240	2210	0.945	0.953
4320	181.2	2290	2230	0.93	0.953
4520	182	2310	2290	0.969	0.953
4760	181.2	2300	2280	0.93	0.93
4920	179.7	2300	2280	0.867	0.813
5120	182.7	2270	2270	0.75	0.735
5320	185.7	2230	2230	0.75	0.774
5480	178.9	2190	2230	0.867	0.86
5640	178.9	2140	2160	0.875	0.891
5800	168.4	2090	2080	0.75	0.68
5960	162.4	2020	2050	0.75	0.649
6080	156.4	2000	2040	0.75	0.649
6200	165.4	2000	1920	0.75	0.649
6360	153.4	2000	2060	0.75	0.727
6440	155.6	1980	1970	0.813	0.805
6560	155.6	1980	1940	0.75	0.758
6440	56.4	980	1970	0.75	0.649
Code:
Wednesday	19	August	2009	18:06:07
'118				'032
 /min	°C	%	 mbar	%	%
1920	34	0	1030	0	0
1960	36	0	1010	0	0
2040	36	95.3	1010	0	0
2160	35	95.3	1250	0	0
2360	34	95.3	1510	0	0
2560	33	95.3	1920	0	0
2840	33	75.3	2510	0	0
3160	33	74.9	2150	0	0
3480	33	75.3	2150	0	0
3760	33	76.1	2140	0	0
4000	34	76.9	2200	0	0
4240	35	78.4	2230	0	0
4480	36	80	2270	0	0
4680	37	80.4	2280	0	0
4920	39	82.4	2280	0	0
5160	40	82.7	2300	0	0
5320	43	83.9	2230	0	0
5480	45	82.4	2200	0	0
5600	48	80.8	2170	0	0
5760	49	79.6	2110	0	0
5880	51	78	2050	0	0
6040	52	77.3	2030	0	0
6160	54	77.3	2010	0	0
6280	54	76.9	2010	0	0
6360	56	76.1	2040	0	0
6440	57	76.1	1970	0	0
6520	57	75.7	2000	0	0
6600	57	76.9	2020	0	0
5400	54	0	1180	0	0
A warm evening, but only 3 power runs done - not thrashing the car to heatsoak it. I am very concerned about the requested fuelling, which seems worse than a month ago.....
