RS6 alloys 18" ....will they look any good?
daz_cymru
Leon Divotee
Jul 13, 2008
602
north wales
ive seen thease on ebay but im not sure if they will look any good as there quite big...there 18" from an a4 s-line and ive got a 1.6s leon.....comments anyone?
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
they look like the rs6 reps which look great on a leon. however if they are original audi ones i think they will have the wrong pcd? someone confirm:)
lc_allan
Northern Monkey
Sep 15, 2006
3,389
You can get PCD adapters as they're 5x112. You'd be better to get the reps and could prob get them with tyres for the same price as the genuine items.
Have a search for 'RS6 Wheels' there is loads of threads and pics on the forum.
daboy3000
No Longer a Seat owner
Jul 2, 2008
710
Oxted
The problem i've found with reps is they are made to a budget and crack easily, the metal is also softer. Get the OEM ones and spend a little more.
Edit: Forgot to say, they will look wicked!
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
How does that work with PCD adaptors to fit the 5x112 in lieu of 5x100, do you still need spacers to clear the Brembo's?
[sorry thought you had an LCR]
lc_allan
Northern Monkey
Sep 15, 2006
3,389
PCD adapters due to their size will act like spacers as well as they are either 15mm or 20mm I forget. Handy for people who do have Brembos or brake upgrades.
As said by daboy, reps can be a bit hit and miss for quality but there is still a lot of people on here with a set.
Not so many with genuine versions.
Ruddmeister
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Mine were 8inch wide rims and 10mm spacers and they were right in line with the lip of the wheel arch.
So if the adaptor is ~20mm you'd need to make sure they were no more than 7.5inch wide rims
Assuming the same offset obviously
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Just looked and the minimum seems to be a 20mm thickness. So yeah would have to get a higher offset. Might be close with the wheel arch as with yours.
Reps with spacers would be my choice as well.
lc_allan
Northern Monkey
Sep 15, 2006
3,389
No I think all Audi's are 5x112. Not sure of the latest 07/08 models but I'm pretty sure they'll still be the same.
jasengine
2.0L TDI
Oct 29, 2007
213
Wiltshire
Hi guys. I got RS6 18", have a look at pic on left! Fitted straight on :p. Oh I did need to get new wheel bolts though, as my original SEAT alloy wheel bolts had the round seating and the RS6's had the tapered type.
But these are not original RS6's by Audi. I have the Italian made versions. Correct offset and centre hole diameter 100mm.
leon291155
193
i have 17'' RS6 on my Leon , they look great and for sure the 18''s will look better..go for it mate
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
i bought mine from willbatch on here, but he rocked them for about 100 miles
powder coating was 50 quid per wheel
