running slow
dragonsnake1985
hi can anyone help me?
my car runs so slow and haven't got a clue why i have tried everything and it still not doing anything i really need to get the car working properly as i am supposed to be doing a reound trip to kent and i don't want my car to fail me
Dec 17, 2006
1,837
Bristol
You might need to give people a bit more info than that, fella.
What engine size is it? When you tried to fix it, what did you try?
dragonsnake1985
it is a 2 l engine and when i tried to fix it i changed the spark plugs, and then the guy at the shop said it could be a some thing with the injector so i got a cleaning fluid for it and now i am lost
It was also standing without being used for about 6 mths
Since i have had the exhaust fixed it runs a bit better but not as it should
Dec 17, 2006
1,837
Bristol
Well the good news is you haven't "tried everything" - but you've made a good start.
Try cleaning the throttle body and changing the distributor cap? Both are very easy to do and fix a lot of common running problems, a search on here should tell you how!
When was it last serviced?
When you say it's "running slow", could you describe that in more detail?
dragonsnake1985
I have changed the distirbutor cap and the rota arm, i don't know when it was last serviced but it is due one.
when i mean running slow when you put your foot down it has no power to it and also it doesn't register over 60mph when i am on the motorway but i know i am going alot faster than it says
another quick question how many miles to the gallon does your car do on average as mine is doin an average of 17 miles to the gallon
dragonsnake1985
Cheers mate i will try that and will let you know
chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
is it standard air filter?
throttle body will make a difference, does it have a de-cat pipe as that is what gives the 2.0 8v its power
Pedro
17 to the gallon!! That's not right for a car with no power!
That suggests it's running far too rich, have you checked the O2 sensor in the exhaust?
dragonsnake1985
I have had a new back box fitted for the mot and hen i had to have the middle bit fixed as it was loose but no i haven't tried that i will try
and yes its a standard air filter and whats a de-cat pipe?
chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
basically a bypass for the catalytic convertor and replaces with a straight pipe, usually helps performance but it actually works the other way on the 8v if thats what you have
dragonsnake1985
yeah its an 8 v and i had a guy check it out the other week when he fixed the middle part of my exhaust and he said it should be all fine now so
so how would correct this problem
