http://www.tsr-performance.com/pages/index.asp
I got mine from them. for my 2.0 16v £350
Only problem was it fouled in bottom of bulk head slightly and eventually cracked the weld. Had repaired and its been fine since! Also i 'modified' bulk head slighly as theres a small box section you can cut away a little. here's a pic of it brand new:
Thought TSR were no more???????
How bigger job was it to modify the bulkhead and does it foul (even slightly) now??
What performance difference does it make?
The car came with a SS exhaust so wanted to spend that money on a 4 Branch and 100cel Race CAT but thought it couldn't be done??
TSR still have ebay shop so dunno?
It wouldn't be big job with manifold off. With on its very technical - long pointed bar and hammer LOL! no probs now! I would recommend checking and modifying before fitting! Its simply a box section and the lower section removed in a very localised place. I will do properly now the car is stripped by cutting out and re-boxing if needed.
I had on rollers and gained 16bhp + extra torque after fitting (was optomistic rolling road but same one i used for before and after . . .)
As for a CAT i got powerflow to make me a de-cat for £40 which is just straight pipe with take off for lamda sensor. Extra noice from this was imence!!!
At the moment i have only 'bodged' the clearence for manifold. But i will be doing it propperly soon.
Fitting not too bad, just a pain!
Have to remove inlet manifold and old manifold was a nightmare to remove. Ended up drilling loads of holes so i could 'snap' old one off and get to bolts on the underside which had all seized. I fitted new head studs too (which needs a head stud puller for). I dont know if all TSR manifolds catch, mine did, but i would try it 1st. For the less hands on people i simply bashed the box section flat at the time because i already had fitted then i noticed the contact with bulkhead and didn't wanna strip out again.
and yeah, was with de-cat too
i will mate, i will be doing full project thread when i get chance anyway!
roly, i like the technical expressions ! lol
