I just wish you could turn off lane departure as a default, having an invisible hand grab the wheel in the middle of a sharp corner or jerk the wheel toward incoming traffic is very distracting!
Bit of Obdeleven Pro code from the Tarraco side but non SFD... could be tried out:
Lane Assist - Remember last setting
  • Control Unit A5 - Driver Assistance
    Select Long coding
    Select setting Perso_HC
    Change Activated to Last_setting
    Press the green button to save the changes
But SFD might stop you fiddling with it. It takes the persistence off to always toggling on. But as said it might be one of the modules that VAG under SFD don't want you fiddling with.
Stop Start you use the air con method rather than the voltage method. It fools the control unit.
- Select Control Unit 08 (Air Conditioning)
- Select Adaptation
- Select Deactivation of Start Stop Function
Taken from
These I guess are all bonnet up mods... don't have the car myself. Worth a try.
I have tried that, unfortunately it dosn't work. Coding goes through fine, but doesn't change anything. Voltage method, as far as I know, also doesn't work anymore.
