samco tip
Nov 2, 2004
9,335
South Wales
You using a mk4 golf TIP? old school.
I have one and the fitment isnt great at all, the end needs to be trimmed a few mm's and theres an extra port that needs to be blanked off.
Any reason why you've gone for a samco tip and not a forge one?
jacko18
AVI! pull your socks up!
Jul 11, 2007
329
Oswestry
www.bebo.com
it was going cheap so got it.just wondering what needs to be trimmed to be honest because i dont wan to tgo hacking away then find iv cut to much off? im guessing you need to trim the bend off the one end and the one port.
Nov 2, 2004
9,335
South Wales
I would PM you back but it might be good for other people searching.
The connection to the turbo needs trimming by a few mm, thats all.
I have the mk4 samco tip and its a pretty bad fit so i suggest goin for the forge one.
Dec 31, 2005
1,856
London
I have the mk4 tip too, i actually prefer the design so the dv sits a bit more forward, mine says forge samco sport on it though so whats the difference?
jacko18
Jul 11, 2007
329
Oswestry
www.bebo.com
cant get the cover back on tho with it.keep thinkin im going to smack the DV when i close the bonnet.
managed to get it on tho was a bit of a pig to fit!
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Designs may look better at the DV but it's actually worse for the car, air gets blown back past the MAF and can cause stalling problems, you may want to look at something like a Jabba heat shielf which moved the MAF further away.
Dec 31, 2005
1,856
London
fair point, does it sit the same on a mk4 golf though, what im asking is that if the maf is the same distance from the dv on a mk4 whats the difference between that setup and mine?
