Seat Altea xl mot failure help
teeth2k
908
sussex
cars just failed on 3 things so looking for Somero advice
Exhaust emissions exceed manufacturers specified limit 8.2.2.2(a)
Have been Advised to buy cataclean to Fix this
Suspension ARM PIN or Bush excessively Worn nearside front lower (rearmost) 5.3.4 (a) (i)
Antiroll Bar ball joint dust cover no Longer prevents The ingress of dirt offside front lower
Can anyone help me with Parts and if ITS posible to carry out The Work myself ?
Please if anyone could help me out
cheshire cat
1,813
cheshire
I think replacement rubbers are easier to find these days if you can crack the joint, the rear bush I guess is similar to the Ibiza one and quite a tight fit unless you use a poly split type not too much work I would have thought if voided it must be fitted in the correct orientation
teeth2k
908
sussex
Thanks for the reply, IV ordered a set of drop links so will just replace them, seen a video on YouTube showing how to replace the suspension bush so again shouldn't be too hard, the emission thing worries me as the new rules state it's either 3.0 m-1 opacity if the manufacturer doesn't state and on my mot form it says 1.00 m-1
My opacity mean value is 2.36 m-1
So I guess I need to loose 1.36 m-1
IV purchased some cataclean as mot centre said this should help
