grq
Giggity
Jun 9, 2005
170
I had a bit of a bump a while back and set off the passenger side airbag and seat belt pretensioner. I have replaced both of these (used parts from ebay) along with a used airbag ECU (same part number and index).
VCDS shows 3 faults: 01222, 01221 referring to the crash sensors along with 00655 resistance too low. When I replace my original ECU the only fault code is the 00655 resistance too low of the seat belt pretensioner.
I have tested the pretensioner connection with some resistors (5ohm) and while the fault code remains it now says resistance is too high, I'm assuming this means the connector/wiring is fine?
My question is how do I get rid of this 00655 code? Should I send my old airbag ECU off to one of these companies to be reset? Any input into this matter will be greatly appreciated :)
Thanks, it's what I have been thinking. Try another seatbelt pretensioner then?
I'm also surprised the airbag ECU hasn't logged a crash??
