We repair selected original SEAT and CUPRA MIB multimedia units with internal audio faults.
This is usually the fault where the screen, navigation, Bluetooth and touchscreen still work, but there is no sound. It can begin with sound cutting in and out, then become permanent. We also see sound stopping once the unit gets warm, the cooling fan running for too long after the car is switched off, and in some cases battery drain.
For suitable units, the fault is repaired inside the original multimedia unit. Your original unit stays with the car, so coding is normally not needed once it is refitted.
This repair is mainly for cars with the basic sound system, where the amplifier is built into the MIB unit. If your car has a separate external amplifier, the fault may be elsewhere.
We are based in Lithuania and work by post with customers across Europe. Units are properly tested before return, and completed repairs include a two-year warranty.
If you have this fault, send us the car model, year, part number and a short description of what has happened. A clear photo of the unit label and rear connectors is always helpful.
-->> More information to our repair page
Common SEAT and CUPRA part numbers:
Label codeOEM part numbers
HB A441 / HBA4415F0 035 020, 5F0 035 020 D
HB A529 / HBA5295F0 035 043, 5F0 035 043 A
HB A678 / HBA6785F0 035 020 B, 5F0 035 020 D, 5F0 035 020 J
HB A6795F0 035 043 B, 5F0 035 043 C
