I would imagine it would be easy if your OK with simple electronics and wiring. What I would do is get a feed of the drivers side light and run that to the passengers side. Check to see if its a constant voltage and a special flashing LED or a normal LED with pulses sent to it, and put in the correct LED accordingly. You may have problems with geting the wiring in to the passengers door though.
