I've had over 135 out of mine. No mods. BHP should be ~180. 0-60 is around 7.7 secs
You'll be very happy if you get one with the basic problems sorted.
Namely, imo, Door Seals, Temp Sensor, Coolant Level Sensor, Coil Packs - not overly expensive, but annoying and potentially damaging.
Those things you list above. Is that something to check on the car before buying 2nd hand? I mean, will this problems appear on the car at some point without fail, should I make sure they car has had these fixed first, or could I be lucky and never have any issues?
Oh, I also think it's strange you've signed up to the cupra forum, are buying a cupra tomorrow, yet know nothing about it!
The coolant temp sensor will definitely need replacing with a green top version. Coil packs will probably go south at some stage as will the MAF. None of them are overly expensive to repair and its pretty pointless checking if they've been replaced.
