Seat Leon Cupra Dump Valve advice
OFI
350
Salisbury
Hi guys,
I am a newbie too, been having problems with power cut off after shifting in 2nd and 3rd, and someone recommended a new dump valve.
Is it easy to fit? Having absolutely no mechanical experience, due to driving fleet cars for years!
Hmm I wonder if mine is at fault then.. To be honest I hadn't noticed any problems but I took someone for a drive the other day and he commented that the power dropped off between gear changes.
Is there any way to tell? Does it throw up a fault code if it's knackered?
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
ive had check dv warnings (leak/pressure loss) logged on the ecu without it triggering the dashboard warning so i doubt it would.:shrug:
caveo
yes if set up right and is still not very loud at all ( even with my big turbo ) and lag between gears is just stupid .... stick to the 007 for performance.
moDojo
Hi everyone....i recently purchased a forge Atmospheric dump valve for my Leon FR 2.0 FR TFsi, and i had it shipped here in dubai. I emailed Forge since i was asking for their help re BOV's ( i just wanted the wooosh sound) and they quickly replied and I was advised by the forge people to get this particular item,
Is it safe to use? will it screw up my car? pls help... im thinking of postponing the install of the valve
MarkE
Acceptable in the 80s
Jul 20, 2003
1,705
Lancaster
www.markeaston.org
Different car, different valve (the setup on the 2.0T is different from the 1.8T), there's no reason to worry.
theyellowone
Im planning on fitting 007p d/v on my completely standard cupra, with a green replacement filter....good plan?
Would prefer to look completely standard but get a deeper sound/whoosh!
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
You wont get a massive external sound difference with a 007P because they are re-circ valves.
If you're looking for the "Jap DV sound" think about the Bailey DV (i think DV26???) as this is more auidible.
What you will get is a "Darth Vader" in your glovebox!
The Forge unit is used by a large majority of the SCN people, and is 100% tried & tested!
If you want street sleeper go 007P, if you want a bit more noise try the Bailey, and if you want Jap sound then think about the Forge Split-R
mark29
dump vavle for 2007 leon
Hi guys .i was looking to get advice on what kind of dump vavle to get for my car is a 2l turbo fsi fr and its got a stage 1 remap .
Could anyone let me know on what kind to get?
Jun 21, 2010
883
Stockton on Tees
your in the wrong section dude, this is mk1 1.8 20 valve turbos not the 2.0 tfsi so i think you will be slow on getting info, you wanna be in mk2. From what i understand though the 2.0 is similar to the 1.8 in the way that a atmospheric dump valve will not work, it has to be a recirculation valve, which takes the air and dumps it back into the inlet rather than to atmosphere, that way the car wont chuck the EML or start running lean/rich. Forge are your best bet and i beleive the valve you want is a revision something or other. if you want the woosh sound your gonna need to run and open cone intake otherwise the sound is muffled by the airbox, also to amplify it remove the bonnet liner. hope this helps a little
mark29
Hi
i need help on finding a dump vavle for my 2007 leon fr 2 l turbo with stage 1 remap.can someone point me in the right dierection to get one for my car?
