I also didn't really lik the wau the wide body ended in the middle of the car so i bought 1 pair of the same sideskirts from JE-Design and modded little after how i wanted it :D
my friend Sadat Painting :)
I got an new downpipe ehere the cat is mounted with V mounts.
ihave an testpipe that i can mount there if i like but i think about the enviroment so the cat is still there at least for now ;)
The catch can before mounting
These are my new brake discs that i hope i can mount this weekend. :D
just waiting on the new brake lines and Motul RBF600 and EBS yellowstuff for f&r.
heres som pics from this weekend :p
so what have you done to it. I see you have removed the door panels and MFD, what did you put in/upgrade too?
What other mods other than intercooler and induction kit.
latest pics? :)
I hated the stereo from day 1 so the other day i took it all away to see what could be doen :)
there ar now pictures in the thread of how it ended.
I now have an Pioneer Avic-F20BT mounted.
I can put a full Spec of the parts mounted on the car in a few minutes :)
Specifikation of the engine and parts mounted untill today :)
Parts come from
www.awesome-gti.co.uk
www.sorensen-performance.com/shop
Software from www.vtech.se
Stereo from www.mds.se / www.mdssweden.com
Motor: 2,0 TSI BWJ
(177 kw/240 hk)
Cylinder/Valves : 4 cyl / 16v
: 1984cm3
Max. power: 369hk
Max torque NM : 475nm
Avgassystem : 3" system med 100CPI Racecatt
Fuelsystem : Direct injection, Turbo, double intercoolers
Fuel : 98 / 99 +
Generator : 140A
Batteri : Optima YT42 x 2
Red Line: Extreme street Performance oil in the engine
Red Line: Heavy Shockproof gear oil in the gearbox
Red Line: WaterWetter i cooling system
These Parts are mounted untill today:
VF-Engineering:
Engine Mount in Polyeretan
Gearbox mount in Polyeretan
ECS Dogboune insert bush
Vtech Fuelpump (Vtech.se)
Forge Twintercooler
Audi S3 Intercooler
Forge Vacum dumpvalve
Forge Short Shift
Forge Short Sideshifter
Neuspeed P.Flo : modified to fit the Cupra engine
Neuspeed CAI
Neuspeed High flow IC Pipe : modified to fit the Cupra engine
Neuspeed Hi-Flow Turbo Discharge : modified to fit the Cupra K04
Nuespeed Powerpulley
Neuspeed Carbon engine cover
Devils own Stage 2 Wather meth kit
Audi R8 oil
Forge red Silicon hoses to intercooler and water system
3" full system Downpipe med 100CPI FIA cert Racecat with V mounts.
3" JE-Design End muffler 4x90mm
Suspension
Front :
KW V3 Coilovers
KW Arbs
Whiteline Anti Lift Kit
ECS Dogboune bush
all powerflex bushes besides the whiteline
Back :
KW V3 Coilover
KW Arb's
Neuspeed Rear Sway Bar Link
All powerflex bushes
Styling:
JE-Design Bodykit,
JE Design full Widebodykit,
JE-Design front grill
JE-Design 3" slutdämpare med 4x90mm pipor :)
JE-Design Ving
JE-Design eyebrows
Carbon Hood
Carbon Roof
Carbon Vingplan
Carbon Diffuser
Pats of Carbon on the front.
Carbon eyebrows
Carbon B och C
Wheels that i have for it:
JE-Design Multispoke 19"
OZ- Racing ultraleggera Black 19"
Tenzo-r type m V2 18"
Vinter rims
OZ-racing Superturismo
And
Original Black 18"
Brakes that are today ( I have new parts soon to be mounted )
Front:
Brembo Slitzed 345x30mm
EBC Yellowstuff Ceramic/Kevlar
Sorensen Performance Brake Lines
Rear:
Brembo Slitzed 286x12mm
Ice:
Pioneer AVIC-F20BT
MDS Dynamic DC6
MDS DS1214 Subwoffer x2
MDS T2
MDS T5
( www.mdssweden.com )
Alarmsystem:
Cargard T70C
GSM/SMS Module
GPS tracking Modul
Nivåsensor
3st 129DB Sirens
1 mounted back and front outside och 1 inside of the car
Extra battery for the alarm system only.
This is the list of things already mounted.
I have a bunch of things that will be mounteed soon :D
That's is great!
Very nice work, some awesome touches :D
Dare I ask what you have planned? Also, what wheels are they? I know they are OZ but not sure of model.
Cheers! ;)
Thank you very much!
Glad to hear that you like it
the plan for the car has always been to have it Nice looking, Fast and with good handling.
It is my everyday car i use it all the year around. :)
i have some more plans for it this winter and just waiting for the last parts to arrive. :D
i already have a Gt3071 kit home. :)
I'm waiting for my new rods and Pistons and a new head with ferrera valves mounted :D
about the rims it is these ones, dont know wich of them you meant? :p
The Summer rims are
Oz - Ultraleggera 19"
if you mean the winter rims they are
OZ - Superturismo 18"
Cheers Mate! :)
fantastic build, looks great especially the customised touches to the body kit and the way that it looks.
Really does make the car look awesome and unique.
Any plans for an LSD (limited slip diff). If you are looking to add the bigger turbo i think this would be a great upgrade to assist with the handling and getting more useable power to the road :)
Also if you plan to race it quite a bit maybe a short-shifter for the gearbox. I find the standard one takes forever to get from one gear to the next!
Still it's a great build and lovely looking car, you should be very proud. It is also veery nice to see that you enjoy driving it :)
Aye that's them, the 18" Superturismo, looks cracking.
Looking forward to seeing the progress of this once the big turbo is on!
Fair play for driving it throughout the year, specially in the snow!!
:D
Thanks!
Yes i'm only waiting for the rods and pistons to arrive then i will mount everything in the same time :D
I'm also waiting for the new head upgraded with ferrera valves so i can rev 8000-8500 something safely. :p
of course i use it all year around :)
In the end it's only a car and they should be used all the time and hard :rocker:
as soon as the progress goes on i will post here..
Thanks!! :D
I'm looking for an Quaife for good price somewhere they are so expensive and can't really afford it now but soon or when i find something with a good price tag on it..
i will buy it :)
I agree about the standard gears, and i have the Forge short shifter and sideshifter mounted already just forgot to post pictures of it..
I probably forgot much pictures :p
Thank you nice that you like it :D
Cheers! :)
Kul att se att det är fler svenskar på forumet :)
Köpte du dina neuspeed delar från nån svensk återförsäljare eller beställde du dom från utlandet??
