Wow this cars had more body work than Katie price.it's stunning tho,well done.I think the new LCD should have looked something like this.
very nice mate :)
Keep up the good work
Thanks mate! :D
i'll do my best to.. ;)
fantastic work, best readers ride yet, welldone :D
Thanks glad that you like it! :D
Thanks mate!! :D
I ment lcr,flaming predictive txt.
hehe thanks :)
I would have been little sorry if it would have looked like this all the work done when i just had to wait for the new one ;) :blink:
TURBO SMART BOOST CONTROLLER Eboost Street
And now it is ready that I will Use Turbosmarts Eboost Street on my car also! :D
I think and hope this will help when going to the GT3071 Turbo setup.
Little info of what the TurboSmart boost controller does :)
Turbosmart Electronic Boost Controllers offer a far more sophisticated solution with a host of boost settings mapped against different triggers like gear change, time, rpm or a manual switch.
Created by racers for racers, the e-Boost range gives you ultimate control over the boost curve with smart features designed for one thing – to exceed your expectations and get results.
All Turbosmart e-Boost Controllers feature our exclusive adjustable gate pressure feature which minimizes wastegate creep and can improve turbo response by up to 1000 rpm earlier in the rev range – this means that you can increase the performance and response from your engine without even raising the maximum boost level.
e-Boost controllers allow the user to control 3 different aspects of the boost curve; the maximium boost pressure (set point), the spool up rate of the turbocharger (gate pressure) and the reaction time of the controller (sensitivity).
Each unit is housed in an aluminium case for durability and strength while a simple 3 segment display is used for clarity and easy navigation in all extreme driving conditions.
http://www.turbosmartonline.com/index.php?id=518
http://www.turbosmartonline.com/index.php?id=42
Every thing will be delayed now im afraid. :(
Not just that some parts are missing to start with the engine..
I might aswell write why here also...
A couple of days ago when i came out to the car on the day it was somebody who has thrashed the car over the night.. [:@]
they have scratched the car smashed the lights broken, broke off windscreen wipers etc..... :censored:
So as off now i dont know when i will get the car back to start with everything..
Bad times :thumbd:
Still waiting for some parts to get started with the engine build.
I have also Ordered a set of these Shifter Cable Bushings.
Will be here Shortly. :)
Where did you order these from?
This car is one of a kind and a real credit to you mate. Amazing, keeping a close eye on these for even more updates im gueesing??
