Ok I'll do this tomorrow but I can confirm. That the lights on the outer are headlight style I believe it's a h1 bulb in place it's not like a 207 bulb (tail light bulb)
In that case all you need I'd some canbus friendly hids and the correct bulbs for the projector....simple as that. Hids4u or hids direct do a terminator kit which is what you are probably after.
These are definitely bi-xenons. Plus, they also have ASF. They will be a bit of a pain in the ass to connect and work 100% oem retrofit. They will use d1s bulbs. Maybe you could get them to work without AFS with chinese ballasts. Oem retrofit would require leveling sensors front and rear, ASF would still be a major difficult puzzle...
You could try these as per HIDs direct, what I don't know though is the type of bulb your projector takes...only you can confirm however if you take a photo of the back of where the bulb goes I can probably give you an idea. The below kit allows you to have H7 bulbs in a kelvin of your choice...4300k is OEM and 5000k has a slight faint blue to it but not much....I would stick with one of those. If your lights are for a D2S bulb you will need a new D2S bulb and harness to go with it...harness is £10 from ebay for the pair and bulbs range from £10 to £120 depending on the make.
http://www.hids-direct.co.uk/new-canbus-terminator-hid-kit-slim-35w-h1-h3-h7-h8-h9/
Also, how did Bethany get on with those French people!?!?!?!![]()
