SEAT Rule
Service / oil inspection light (how to reset)
May 26, 2020
Manchester
Hi I own a 2015 Mk5 SEAT Ibiza that I serviced in September this year, but was having problems resetting the service / oil inspection light, but I managed to work it out in the end.
Anyway the last job I had to do was turn off/reset the service inspection light, so I followed the procedure in my owners manual to reset the service light/indicator but it didn't work, also tried it from what my Haynes manual said and again no joy.
This is what they both say.
With ignition switched off depress & hold the right button under dash dial's, now switch ignition on & release right button and press left button within 20 seconds.
Service light should go out.
Turns out the above procedure works on SEAT Ibiza's with red LED dash from 2008 to roughly 2011 or 2012
Ibiza's with white LED dash you have to do the following procedure.
With the ignition switched off,
turn Hazard's on wait 3 seconds, now depress & hold the right button under dash dail's, now switch ignition on and release right button and quickly press left button, the service light should reset.
Now turn off Hazard's.
This worked on mine with the white LED dash 2012 to 2017
Hope this helps out others
Si
May 26, 2020
Manchester
ABSOLUTE LEGEND !! To be honest I had given up as presumed it was a fault and everybody boosting vids which I had already done .
This worked 1st go and both service and inspection back to 20k and 9600 .
Thanks for taking time to reply my friend ..I owe you a pint after lockdown
SEAT Rule
188
62
Good to hear this has helped someone out, I must admit it took me a good 20 minutes to work out how to do it, as like I say the owners manual wasn't updated for the later models, and the same with the Haynes manual.
Si :thumbup:
