VAG Diesels Rul
61
Hi, I have got a 51 reg 1.9tdi 110 and it has got 75,000 miles on the clock.I have looked in my service manual and I am a bit confused when it comes to the cambelt change.It had it done when it had 57,000 miles on the clock which relates to the 90,000km it says in the book.Has this engine got an injection pump because if it does,it says it needs replacing every 60,000km.Also what other things do you recommend doing around this kind of mileage?
Any info would be greatly appreciated.
I can see what you're saying.If you look in your inspection and maintenence plan book on page 10 it says,every 90,000 replace (only tdi engines) and then it says every 60,000 replace (tdi engine with injection pump.)
cheers
