HenryCupra
Does anyone have a problem with short keyfob battery life. I have had the cupra for 10 months now and have had to replace the CR2032 battery five times since.
I read in a post sometime ago by flapper ,I think, that it was possible to fit two cr2016 into the same keyfob using a CR2032. Has anyone else tried this. If so how did you do it, i.e. run the batteries in parallel.
This is really starting to get on my nerves. If there is no solution for a retrofit. Does anyone know if it is possible to get a new key that uses the cr2016's instead. Car is still under warranty, do you think this would be a warranty issue.
Any constructive suggestions would be appreciated.
