Short shifter / shorter gear stick question...
HMSPresident
Ok, so I understand a short shifter changes the actual linkages to the gearbox, but it doesn't affect the actual gear stick, does it?
I drove a BMW 320CD with the M Sport pack the other day, and was suprised at how short the actual gear stick was...
So the ideal set-up work be a short-shifter the shorten the linkages, and then something like a stubby S3 gear-stick to shorten the actual stick?
Presumably then, you could fit an S3 stick without making any changes to the gearbox?
BeezerDiesel
Minus a Diesel Beezer
Aug 3, 2002
1,852
Exeter
Beemer has a short stubby gear lever because of the big central tunnel housing the prop shaft running up the middle of the car. You may find the gear lever sits a bit low if you cut it down too far.
bigjode
504
I cut my gear lever down - by about 1 inch. Its just a case of cutting off how much you want and sticking the knob back on. I've got a little richbrook knob so the shorter shaft suits it.
CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
Do you have a short shifter at the box too?
bigjode
504
Not yet. I rang Westec and they said it would be a couple of weeks before they had one in stock.
Not sure if i'll bother now anyway - the gears are notchy enough I think and a short shifter just highlights that from what i've heard
HMSPresident
True... I have my seat as low as it will go, but it is something i'd need to think about.
Have you got any pics?
CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
I don't think its any more notchy with my short shifter, although as you say, its is quite notchy.
Westecs couple of weeks can be a couple of months if it's EIP, they order in bulk I think.
ibiza_95
1.8T MK2 Conversion
i cut mine down, feels ten times better loads more sporty, got a momo gear knob which is quite tall so it needed to be cut for that but i was playing in a few sports cars today and my gear movement isnt far off, id guess its only going to make it a slight bit harder to get into gear due to the lack of leverage if you cut it down but thats it.
no idea bout the short shifter
