Shortened drop links MK3 Leon FR
Apr 4, 2022
Hi guys!
I've lowered my car on a set of coilovers, I now need to get shortened drop links as it's knocking off the driveshaft.
Does anybody know if there is a car with the same drop link fitment that would fit a MK3 Leon FR that are shorter than the standard size?
To my knowledge, the standard size is 335mm so would need something around the 300mm region with the ball joint heads facing the correct direction.
Any help would be greatly appreciated!!
TONRIK91
10
13
Hi guys!
Hi! Im having the same problem! Just put some coilovers for my FR 2018 and theres cracking noises. Did you fix this?
DEAN0
Old Git
Feb 1, 2006
5,439
Preston - UK
I’ve got a clunking noise on coilovers with adjustable drop links, everything’s tight. Did you get it fixed??
Just a suggestion.
Remove a drop link on one side of each anti roll bar ( now the roll bar is eliminated )
Go for a careful drive ( car will roll more now ) - and see if the clunk has gone.
TONRIK91
10
13
No and Im having the same clunking noise. Im really frustrated because a thought it was the front shock mounts and I change them.
Thinking now it is the sway bar..
The noise happens when I accelerate at first, when going through bumps, and turning left or right.
Sent from my SM-G981U1 using Tapatalk
