Sidelight problem
wrayvon
408
Bingley
Got a strange one, none of my sidelights on the offside are working. I swapped the bulbs on the rear over and the bulbs definitely work, so I'm thinking it must be a fuse related issue?
Anyone have any idea if this is case,and if so which fuse is it? I can't see any that are broken nor does it mention sidelights in the manual :(
Any help most appreciated!
Badger
2,643
7
Newcastle, Staffs
If all the fuses are ok and checked them against the fuse card (one located in the FAQ section) then you'll need someone with a continuity tester to check wiring.
wrayvon
408
Bingley
Spoke to a friend of mine who works in a car garage, he sent me this. It turns out f6 and f7 are the ones relevant. One for each side!
wrayvon
408
Bingley
Good news, it is now fixed.
Using the image above, the fuse for nearside is the one highlighted and offside is the one above it.
