Slowly failing MAF?
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
I have noticed the car surges through the rev's on a cold start and have noticed is that my top speed is slightly down, so I belive the MAF is failing. After all it is the same MAF after 72,000 miles!!
After a quick maf run it seems to be ok it's pulling 150g/s however it did used to pull 158-161g/s at the same revvs with the same outside air temp. Can the MAF slowly fail like that, or will it normally go down in much higher rates?
So far there has been no signal to low errors, but I think it's just a matter of time!
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
My MAF rate varies, sometimes its 155g/s, others its 145g/s, sometimes its in between.
I would only think its failing if its signifigantly lower than usual.
Radek
70
I've done some tests few days ago :
,,RPM,Load,Inj. On Time,Mass Flow,,RPM,Mass Flow,Load,Ign. Timing,,,,,
,34.84,1520,69.9,9.84,22.94,35.14,1600,25.81,100.0,12.0,,,,,
,35.44,1680,82.0,10.25,28.67,35.74,1760,31.00,100.0,9.0,,,,,
,36.04,1800,91.7,11.48,34.64,36.34,1880,37.56,99.6,6.0,,,,,
,36.64,1960,101.5,12.71,39.61,36.94,2040,43.14,100.0,6.0,,,,,
,37.24,2160,110.5,13.94,45.94,37.54,2240,46.83,100.0,6.8,,,,,
,37.84,2320,110.5,13.94,48.72,38.14,2440,50.11,100.0,9.8,,,,,
,38.44,2520,109.0,13.94,51.19,38.74,2600,53.75,100.0,11.3,,,,,
,39.14,2720,106.8,13.53,56.86,39.44,2840,59.19,100.0,12.8,,,,,
,39.73,2920,109.0,13.53,61.78,40.03,3000,65.17,100.0,13.5,,,,,
,40.34,3120,110.5,13.94,66.08,40.65,3160,67.44,100.0,13.5,,,,,
,40.93,3280,109.8,13.94,69.31,41.24,3360,71.58,100.0,12.0,,,,,
,41.55,3480,109.0,13.94,73.25,41.84,3440,31.89,7.8,12.0,,,,,
Looks like it's 25.81 - 71.58 between 1520-3480 RPM
That's bad , isn't it ?
Radek
70
Trafiic , you know :)
Will hit the red line in the evening and post the results
Radek
70
OK , got it ! 3-rd gear run , not possible to run on 4-th unfortunately
Code:
Sunday,21,May,2006,19:22:27
6K0 906 032 AQ ,,1.8l 20VT EU2       0001,
,Group A:,'002,,,,Group B:, Not Running,,,,Group C:, Not Running
,,RPM,Load,Inj. On Time,Mass Flow,,,,,,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, /min,%, ms, g/s,STAMP,,,,,STAMP,,,,
,0.29,2240,74.4,10.25,37.19,,,,,,,,,,
,0.59,2280,88.0,11.07,41.53,,,,,,,,,,
,0.89,2320,96.2,12.30,46.31,,,,,,,,,,
,1.19,2400,102.3,12.71,49.50,,,,,,,,,,
,1.49,2520,105.3,13.53,51.39,,,,,,,,,,
,1.79,2600,106.8,13.53,53.25,,,,,,,,,,
,2.09,2720,106.8,13.53,53.89,,,,,,,,,,
,2.40,2800,106.8,13.53,57.83,,,,,,,,,,
,2.69,2920,108.3,13.53,60.03,,,,,,,,,,
,3.10,3000,109.8,13.53,64.42,,,,,,,,,,
,3.40,3120,109.8,13.53,66.61,,,,,,,,,,
,3.69,3200,109.0,13.94,66.39,,,,,,,,,,
,3.99,3320,109.8,13.94,69.89,,,,,,,,,,
,4.38,3440,109.0,13.94,70.44,,,,,,,,,,
,4.69,3520,107.5,13.53,72.56,,,,,,,,,,
,4.98,3600,106.0,13.12,72.17,,,,,,,,,,
,5.28,3720,106.8,13.53,75.56,,,,,,,,,,
,5.59,3800,106.8,13.53,77.56,,,,,,,,,,
,5.89,3880,106.8,13.53,79.47,,,,,,,,,,
,6.19,3960,106.0,13.12,82.08,,,,,,,,,,
,6.49,4080,106.8,13.53,84.19,,,,,,,,,,
,6.79,4160,108.3,13.94,86.17,,,,,,,,,,
,7.09,4240,109.0,13.94,90.50,,,,,,,,,,
,7.39,4360,109.8,14.35,92.61,,,,,,,,,,
,7.79,4440,112.8,15.17,96.86,,,,,,,,,,
,8.09,4560,112.8,14.76,99.36,,,,,,,,,,
,8.39,4640,112.8,15.17,99.64,,,,,,,,,,
,8.69,4720,112.0,15.17,101.72,,,,,,,,,,
,9.09,4840,112.0,15.17,103.89,,,,,,,,,,
,9.39,4920,112.8,15.99,106.72,,,,,,,,,,
,9.69,5000,111.3,15.17,108.78,,,,,,,,,,
,9.99,5080,111.3,15.58,108.94,,,,,,,,,,
,10.29,5200,110.5,15.99,110.83,,,,,,,,,,
,10.59,5280,109.0,16.40,109.94,,,,,,,,,,
,10.89,5360,109.0,16.40,112.36,,,,,,,,,,
,11.19,5400,107.5,16.40,112.28,,,,,,,,,,
,11.49,5480,106.0,16.40,112.94,,,,,,,,,,
,11.79,5560,106.0,16.40,113.58,,,,,,,,,,
,12.09,5640,105.3,16.40,115.47,,,,,,,,,,
,12.39,5720,105.3,16.81,115.19,,,,,,,,,,
,12.69,5800,105.3,16.40,117.42,,,,,,,,,,
,12.99,5840,105.3,16.40,117.83,,,,,,,,,,
,13.29,5960,104.5,16.40,120.14,,,,,,,,,,
,13.59,6000,106.0,16.40,120.78,,,,,,,,,,
,13.89,6080,104.5,16.40,122.47,,,,,,,,,,
,14.19,6160,105.3,16.81,123.33,,,,,,,,,,
,14.49,6200,103.0,16.40,119.72,,,,,,,,,,
,14.79,6240,95.5,14.35,113.81,,,,,,,,,,
,15.11,6280,97.0,15.17,117.83,,,,,,,,,,
But I'm afraid my DV is leaking :( Can hear that :(
2-nd gear run
Code:
Sunday,21,May,2006,19:31:18
,Group A:,'115,,,,Group B:,'118,,,,Group C:, Not Running
,,RPM,Load,Absolute Pres.,Absolute Pres.,,RPM,Temperature,Load,Absolute Pres.,,,,,
MARKER,STAMP, /min,%, mbar, mbar,STAMP, /min,°C,%, mbar,STAMP,,,,
,0.29,2320,75.9,1490.0,1060.0,0.59,2440,27.0,54.5,1190.0,,,,,
,0.89,2600,94.7,1520.0,1330.0,1.19,2800,27.0,45.5,1430.0,,,,,
,1.49,3000,107.5,1510.0,1490.0,1.79,3240,26.0,45.5,1520.0,,,,,
,2.10,3440,110.5,1480.0,1530.0,2.50,3800,25.0,42.7,1500.0,,,,,
,2.80,4000,106.0,1490.0,1490.0,3.10,4120,25.0,45.5,1480.0,,,,,
,3.49,4480,110.5,1460.0,1490.0,3.89,4760,26.0,50.6,1500.0,,,,,
,4.19,4960,112.0,1470.0,1490.0,4.49,5160,27.0,52.2,1480.0,,,,,
,4.80,5360,108.3,1490.0,1490.0,5.09,5560,29.0,54.1,1480.0,,,,,
,5.39,5760,104.5,1500.0,1470.0,5.69,5920,30.0,58.0,1460.0,,,,,
,5.99,6120,103.0,1420.0,1450.0,6.29,6280,32.0,61.2,1440.0,,,,,
,6.59,6440,99.2,1370.0,1450.0,6.89,6600,33.0,25.1,1440.0,,,,,
,7.19,6400,19.5,990.0,1420.0,7.49,5720,33.0,0.0,1210.0,,,,,
Wot do you think ?
Radek
70
How to double check boost leak ?
I hear it from inside the car . And sound like quiet WRC blow off valve when changing gears :O
I have standard plastic DV
