davidgoodwin180 Active Member Jul 26, 2009 57 0 www.purbeck.photos.co.uk Aug 21, 2009 #1 hi guys, i am trying to find out what the small tanks/reservoir thing that looks like a dump valve that sits behine the dump valve is. thanks David
Shaunyboy Aug 7, 2009 1,395 0 Manchester U.K Aug 21, 2009 #2 There is no tank, the only thing behind the dumpvalve on the bulk head is heatsheild and the abs pump from what i can remeber.
Ronin225 Active Member Jan 17, 2008 4,647 22 Worcester Aug 21, 2009 #3 Unless its the vacuum resovoir for the N249 Over the last 2 coil packs but other than that ???
Markyboyt Dec 6, 2008 612 0 Shropshire Aug 21, 2009 #4 is it not the little breather or whatever it is into the TIP?
davidgoodwin180 Active Member Jul 26, 2009 57 0 www.purbeck.photos.co.uk Aug 21, 2009 #5 it is joined to the turbo intake pipe and has a large pipe running to the top of the engine. it looks just like a plastic dump valve but it doesnt have the nipple on the top. thanks David
Mylo Aug 24, 2007 800 0 Aug 21, 2009 #6 air pump(pressure release valve) for the pcv system Last edited: Aug 21, 2009
davidgoodwin180 Active Member Jul 26, 2009 57 0 www.purbeck.photos.co.uk Aug 21, 2009 #8 if that was messing around could it cause my vag.com (Pressure Drop between Turbo and Throttle Valve (check D.V.!). thanks David
davidgoodwin180 Active Member Jul 26, 2009 57 0 www.purbeck.photos.co.uk Aug 22, 2009 #9 not the same engine or even car but this is the tank thingy.
