snapped wheel bolt
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
as i was removing my alloys today one of the bolts on a rear wheel sheared off , i still have 3 bolts on and a locking one (4 in total) , wats the chances of anything bad happening running with a bolt out , as i can get no threads engaged on the damaged one
and does anyone know the price of a rear wheel hub , ibiza mk4 (disc brake)
CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
Can't you get it drilled out rather than get a new hub? Its easier than it sounds with the right drill and bits.
I doub't that you are in imminent danger!
samjamesmanning
Its happened to me before....a few times...if you get a small coal chizzle you should be able to tap it around as there is no tension on the threads. No need to take the hub off!
mrcoyote
See no evil...
Jul 26, 2004
2,624
Pretty sure Toxxin replaced the rear hub on his old TDI with one from ECP, so it might be worth giving them a call.
