Let's pretend you didn't put that up Wayne that's gash lol
Want this one so if some one can find out where I will love you forever
Tom wish I could get the mani on but I can't and don't think nicks about ,
Also don't even know if I'm going to the rr day just been told I'm going to see labyrinth the same night
Got more little bits to do on the weekend change the thermostat again as the one I replaced was broken so ordered a neuspeed one from awesome gti , I have the wmi solenoid to fit and wire up a red led to the float switch for the tank , all the wires are run so wont take long , I've decided against keeping the wmi controller in the ash tray so I'm going to remove the ash try and have a sheet of carbon fiber with the controler inside and the red led warning light so it's on display to give me enough warning , I can still hide bits behind it and still get to the obd port , also have the new turbosmart dv to fit and test , then I can test the wmi out to see what gains i can gain
Zzzzzz boring.... lol..
Only joking :) Looking forward to seeing how you get on with the wmi gains ;)
Fitted my carbon bonnet today :) let me know what you all think ???? Needs a little adjustment and spacing on the drivers side but other than that it's all good my aero catches lined up a treat :) ,
Also fitted my turbosmart dv but its going to take a while to set up correct , started to take the climate control out to measure up the carbon sheet , will start on it tomorrow tho :) shouldn't be to long then I can go for a drive to test the wmi
