Got more little bits to do on the weekend change the thermostat again as the one I replaced was broken so ordered a neuspeed one from awesome gti , I have the wmi solenoid to fit and wire up a red led to the float switch for the tank , all the wires are run so wont take long , I've decided against keeping the wmi controller in the ash tray so I'm going to remove the ash try and have a sheet of carbon fiber with the controler inside and the red led warning light so it's on display to give me enough warning , I can still hide bits behind it and still get to the obd port , also have the new turbosmart dv to fit and test , then I can test the wmi out to see what gains i can gain
Fitted my carbon bonnet today let me know what you all think ???? Needs a little adjustment and spacing on the drivers side but other than that it's all good my aero catches lined up a treat ,
Also fitted my turbosmart dv but its going to take a while to set up correct , started to take the climate control out to measure up the carbon sheet , will start on it tomorrow tho shouldn't be to long then I can go for a drive to test the wmi
