mark tfsi
hi all,lifted the bonnet and the lining was soaked,where does the water run in from and how do i stop it thanks.
Had mine done a month ago whilst it was being seviced
Seat's FOC fix does not work on mine. . .
TimSawf,
Thanks for the input, its a new piece of sound deadening as the old one was really sagging quite badly.
I will get the fix, using the foam strips that SEAT has now come up with as detailed in the link posted in this thread above.
I simply removed my sound proofing =)
Well I have mine removed to, but i doubt anyone is to fussed about the insulation, it's what the water drops on that's the problem. . .
I'm thinking of doing the same - stops it altogether then.
With the insulation removed the water will drop closer to the firewall and not cause the coil corrosion issue.
It may have worked for you , but not every car is built the same , only some cars suffer from the rusty coil pack issues.
I see.
So if you own a Leon you should always park it indoors![]()
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
No you need to live in a country where it doesnt rain![]()
