davidol said:
what sort of money would the spec be on yours based on what i currently have in my profile, i think the biggest
problem with companies like yours is people want a fixed price they can look into and then just say yes do it, i appreciate there can e hiddern costs along the way but you guys seem to have vast experience on this so should be covered!
Yours sounds fantastic, i'd admit i'd love to break the 300+ barrier but im not sure my wallet could take the damage and traction must surely be a issue
do you mine if i ask how old you are mike? any chance of that passenger ride sometime?
Myself and Adam are 25 mate, both had the cars when we were just 21, (cars only year old then)
when its running tidy No prob with ride, Adam will do the same im sure.
its hard to say cause I have gone OTT in some areas, just been gradual, List as follows:
Engine:
17 CORE FMIC with 2.5" Mandrel Alu Pipework
7 Core Oil cooler and thermostat sandwich plate
Bumper Located Induction with 3" Alumiium Pipe
Aluminium big bore turbo inlet pipe
Aluminium Catch Tank
Audi S4 MAF Housing
Audi S3 MAP Sensor
Evo shield intake gasket
AM04 stage 2 (being fitted)
Sports actuator
Cold side DV relocation & forge DV
Large bore Cast Mannifold (Being fitted)
Vibratechnics Performance Engine Mounts
Vibratechnics Box Mount
Spec Stage 3 Hybrid 6 Puck 228ml drag clutch
Spec Billet Steel flywheel
440CC injectors
S3 Fuel Pump
3" Downpipe, 100cell race cat
2.5" exhaust system
N249 valve Bypass kit
Denso irridium plugs
B&M Quick Shift
Jabba remap to 25-27psi 'peak' boost with S3 TCS
Battery relocation to Boot
KW Phase 3 Coilovers,
Brembos,
Pagid rears,
Strut Braces
Rolled arces
Oil Temp, Oil Pressure, Boost, AFR, Charge temp gauges
Extra Security
sure I missed a few bits
