Status
Not open for further replies.
love the van
its lurvly
boys i was practising this morning before work, i is getting better. yesterday before i had joined up with you lot, i had played 1 race, hard to get enough CR to fully mod the cars though, and seems hardly worth selling the cars i got. back in work in 8hrs! but i'll be on as soon as i get home which'll be like 5ish
I need to get some lockers really. Seen mcgard ones in halfords but i didnt know which ones to get. And i'm running spacers on the back so not sure they'll be ok.
Phil, could go halfy's on a set of Longer lockies for the back and order a spare key, and split it 50/50 if you wanna. As i've got lockers on the front, but not the back due to the longer bolts needed.
Same situation as me only I did have longer lockers on the back.
Had 2 keys as different lockers were used on the fronts until I could cut the longer ones down also to be used on the front. Then I lost the key to the fronts, got Westec to take out the fronts as I'd lost the key. They only went and whipped the rears out!! Been without since, idiots.
I cant ****ing belive it, mate of mine found my locking wheel nut key 5 miles from my house in the gutter, 4 days after I lost it. Im playing the lottery
think the weather put loads of ppl off, someone mentioned wellies at some point!
Matt sounds good but i'd need to take out some of the shopfitted shelving they've installed as the van is basically split into three different areas inside, quite cool actually as everything has its place rather than just being lashed in.
Matt what exactly made you pull over and see if your key was in the gutter in the first place lol
It cleared up, was a bit muddy in the centre patch of grass but most of it is on tarmac, went past a nasty accident just outside brunters tho, mk1 golf smashed up side on into a telegraph pole which snapped like it was a cocktail stick :(
Rest of it was pretty good though, only stayed a couple hours but was worth the drive
Kind of glad i didnt go now, even tho i cant without a car! lol.
Parts so far got..
Rods being shipped
S3 Maf bought
G60/ABF flywheel sourced
Just waiting for paypal to stop being dicks and i can order some more bits.
Anyone adjusted the firmness on their FK's?
My car scrubs a little with people in the back, but i dont wanna raise it, so was thinking of firming the backend up. Anyone else done it, and whats your opinions?
Status
