Status
Not open for further replies.
Have done Dave, didnt see it earlier today mate, soz!
All sorted now, cheers!
Dumb ass fault code still ongoing!!! Its starting to get like the Lost series now, ongoing, and no resolution insight!
Tom, i'm stupmed.
Doesnt look like its got a boost leak.
Next to check....
All TIP connections.
DP studs to see if any leaks are about
MAF ok?
Is it a stage 2 map? You got a 4 bar in?
Its a stage 1 remap, with standard 3bar fpr.
I think i'll replace the Fuel Filter, just as a treat.
I'll double check the tip, may even go underneath and have a look, but i'm sure that was ok the otherday, when i fitted the DP.
Will check the DP studs, but i'm sure they'd be ok.
MAF seems ok, but i'll log it again. I took the MAF out and gave it a clean last night, but i'll take it apart today, and give it a damn good soaking with contact cleaner.
Sorry for making you feel my pain Phil, I'm running out of idea's.
No probs tom, we're all here to help.
You sure its stage 1 tho? Might be worth logging injector duty cycle as well.
Log 002 as well so we can calculate your a/f.
What do i log for injector duty?
Do you want me to log them at the same time or seperate? ie injector duty at same time as 002, or is it the same thing?
Got a nice stretch of road outside work so can pop out a few times.
Have a look at 033 and 036, whilst sitting still and revving it to see wha the volatges are. Should cycles between 0 and 1 iirc.
Are you 100% sure its stage 1?
Also, bring up 032, in the car park. And write down the numbers in teh columns. But make sure you write them down after the lean code has appeared and before you clear the codes.
I'm pretty sure its stage 1, but no way of really knowing.
No other codes, did get a low fuel fault, but I was generally low on fuel, and then filled up.
Just ordered a Fuel Filter, so we'll rule that out soon.
Will try and pop out soon and do the logs.
Speak to Kev @ revo to see if theres a way of checking.
One of the boys in work had his revo'd S3 nicked this week, ****ers broke into his house in pontypool and took the keys and drove off. Hes tamping.
bump to the top
whats everyone up to?
i've been wrecking me mams kitchen DIY stylee.. awesome **** happening big tools too play with but now i have to wait for the parts to hold up the ceiling before i can continue my work!
for some reason karl you strike me as completely useless with tools :) popped over to B&Q to get some tool boxes that suit me better for my firstday tomorrow, excited and shitting my pants at the same time :)
also picked myself up some smoked hella anniversary style lights for the golf, all fitted and looking pimp, think im gonna pull my finger out now and crack on with her!
Status
