Status
Not open for further replies.
I think my first Coil pack has gone, loost boost, and it sounds like i'm driving a cross between a scooby, a harley, and a 3 wheeler! LOL
Cant get the bast@rd last coil off to check it either, though I suspect that this is the faulty one. Grrr.
forbez- exactly the same problem as mine! new coilpack arrived this morning from vagparts, hopefully it was that! vag-com said misfire on cylinder 4, moved coilpack to cylinder 1, and then code changed to cylinder 1. so had to assume coilpack! :)
I got 2 spares if your desperate
cheers for putting car on vag com mate. just went out and got maf now. will be fitting after i have done the bypass!
thanks again
just in the middle of it now. having bacon sandwich thanks to nan! i am actually moving everything as well. hidding everything!
just fitted my n75j valve and new coilpack. what a difference that valve has made. pulls so much harder now. wasn't expecting it to do that at all! fingers crossed no limp mode! :)
help. done my bypass and i know it is correct! folowed the pictures to a t! now my car is running like a bag of ****! will not rev past 2500. i had a problem earlier with it starting!
i have however put new pipes on for the fuel line.
anyone think of anything it could be
check the hose going to the actuator and dump valve are correct
rhys - ill chuck you a pm. im asuming you have everything needed?
o'leary - i want your babies
Status
