Speaker upgrade questions
Leonfrdiesel184
162
37
Hi everyone obviously keeping my options open to the seat sound upgrade but I just wondered if anyone upgraded there speakers with aftermarket ones ?
What size are the speakers in the Leon MK3.5 fr? Front and rear.
Can you get to the tweeter behind the column and upgrade them?
Are the speakers glued in and would you recommend sound deadoning to be fitted at the same time ?
What are the standard rms power rating of the standard speakers ?
Can you put in a centre speaker without having to have the head unit settings changed ?
And finally can the standard head unit run an amp to in turn run a subwoofer ? Anyone had an underseat one fitted to save space?
Cheers everyone and help would be great on this
Reactions: AlperUtkuCeylan
Leonfrdiesel184
162
37
No you cannot add the centre speaker or the sub without changing the wiring and the infotainment configuration
The only way you can run an amp is via MOST if you have a virtual cockpit, or via a high level output taken from a rear speaker channel
Thank you so much for that mate how does the subwoofer work for the seat sound then? What is the actually power for the seat one ? Thanks mate
cairus
1,572
552
The Beats sound system was also available with CAN control. We have it
TripleBob
379
278
From having looked at this in great detail- without a lot of hacking of wires and taking feeds from speakers etc, it’s just not worth the hassle
It’s much easier to just get the kit from @East Yorkshire Retrofits or pop up and see him (which is what I did), have a lovely old day at the seaside and then drive home with massively improved sound! The Seat sound setup is honestly great.
In fact I’d argue you’ll hear better results from the Seat sound kit and spending the leftover budget on soundproofing/damping the doors than trying to hack in aftermarket stuff
SuperV8
1,869
940
Standard front door speakers are 8"
Personally I find my standard system decent - I have really nice amp and sub sat in my cupboard at home from previous car install - I sometimes think of fitting them - but then think I'm quite happy as is, and would rather not compromise my boot space.
If I did want to upgrade - I would be doing sound deadening first before any speaker/amp etc...
AlperUtkuCeylan
58
21
You should definitely do some sound deadening to doors. Especially the midbass quality quadruples with only sound deadening. I did vibration dampening and foam.
Chariot
41
13
--- fronts are 8inch circular midwoofers
--- rears are 6.5inch circular mids
--- I am assuming you are talking about the A-pillar (=column) and yes you can get there and upgrade them, BUT...
--- the tweeters are glued in the A-pillars. Sound deadening is mandatory if you want to do your equipment justice.
--- don't know, somebody please answer this
--- Nope, for a reason unknown to me, the Pin Assignment will change, so if you add hardware, you must change software
--- Yes, you can have the HU feeding into an Amp into a Sub
grabania
197
Warsaw, Poland
grabania.pl
MIB2 is capable of 6-channel output. When car have 8 speakers those channels are distributed like that:
1. front left tweeter
2. front right tweeter
3. front left woofer
4. front right woofer
5. rear left (combined)
6. rear right (combined)
When there is a Seat Sound System parametrisation the distribution looks like that:
1. front left (combined)
2. front right (combined)
3. rear left (combined)
4. rear right (combined)
5. center
6. subwoofer
That's why when upgrading from 8 to 10 speakers you have to connect front tweeters with front woofers :)
Reactions: SuperV8
