Spongy Brakes.
bubbles1
Nurburgring Lover
Dec 28, 2008
490
Llandudno
Having problems with spongy brakes on my tdi 130 ibiza! As i do a lot of track days the brakes get a hard time and seemed spongy for a while so upgraded to 312mm torox 6 potters with big improvements but still having spongy a pedal. I have bled them and pedal feels very solid with engine off but switch it on and pedal is spongy again. Is it the servo ? Any one any ideas? Cheers in advance:)
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Have you had the system pressure bled? sounds like you might have air in there somewhere, possibly in the ABS resevoir .....
I watched a garage who knew what they were doing bleed mine and it took them 2 attempts with a full pressure bleed before it was right.
bubbles1
Nurburgring Lover
Dec 28, 2008
490
Llandudno
Yes i used the pressure bleed method (one man opperation) but did'nt bleed the master cylinder (will have a go asap). Seems odd pedal felt firm with engine off then went all soft with it running:confused:
1.9...stefan
HYBRID???
Aug 21, 2008
705
grimsby
exactly the same as mine....1 way you could check is using the oldfashioned way crack a nipple off, submerged in fliuid pipe etc, and then press the pedal.... the pedal should go to the floor but wouldnt advise as master cyclinder seals can fail
i bleed both nipples on the master cyc got 3 big ass bubbles and then straight away fine.... quick bleed up of all the other corners and all should be good
cheers
dirtysac
250
Yorkshire
Ya the brakes are a bitch to bleed currently. I changed my brake fliud a month ago and took two attempts to get it bleed through properly. You have to check and re-check then top it all up and pray.
bubbles1
Nurburgring Lover
Dec 28, 2008
490
Llandudno
Just spent an hour this am bleeding system again with my gunsen pressure bleeder from halfrauds and all is well!:) I used the pump the pedal way while the pressure system was on and that did the job. Cheers all:)
bubbles1
Nurburgring Lover
Dec 28, 2008
490
Llandudno
The not so spongy brakes!
