Squeaky interior panels
loonitic
59
Hello I seem to have an odd issue with squeaking interior rear door and boot trim on my lcr, basically if I go over any sort of bumpy road the trim seems to be making a noise. For the door trim I have replaced all the clips that hold it on the door and the metal clips that hold the trim to the boot lid but still squeaks.
Now I have tried to see if anything is rattling and so on but nothing, any tips or suggestions I could try to fix this?
Gaz7
385
I've managed to eliminate some squeaks, the art is in locating exactly where they're coming from, have had some luck in coating contact/ clip areas with lithium grease ( obviously non- visible )
Ash-Kennard
why are you reading this?
Jul 31, 2008
286
portsmouth
I was out doing this last weekend, Lithium grease has helped with the majority, boot it spot on now, door only a little bit so a marked improvement. My biggest pain is the creaky dash. need to foam pack it, but not located the source of the sound yet.
