Ssss noise when accelerating
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
Hi guys, ive noticed recently sometimes when i push the accelerator down i get like a ssss noise for 2 seconds when i press it
anything to worry about?
________
Weed vaporizer
Big roars
26
Chesterfield
My Ibiza FR makes a quite loud noise when boosting but it only happens when the engine is fully warmed up. It never made this noise before and i am starting to wonder if it is an air leak somewhere althogh there is no difference in power. Has anyone else had a similar problem ?
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
Your turbo will make some woosh/hiss noises and the noises will be different depending if the engine is cold or hot. Don't worry.
RaggedLob
The worst is yet to come
Mar 29, 2009
179
Thatcham, Berkshire
Bear in mind also that the 1.2 is chain driven- meaning it will make that hissing sound at low revs, the one so common with 1.2 Corsa's
but hey, at lest there are no belts to replace! :p
Big roars
26
Chesterfield
It never made the noise before. I had it remapped and it has been running fine for a couple of months and has only just started to make the noise. It is very noticeable even with the windows up
Nath.
Jan 1, 2006
8,619
16
Maybe you have the early signs of the boost pipe popping off. do a search for boost pipe and all will be clear.
2 Many Ibiza's
I wouldn't worry, i have an open cone air filter on my FR, and with the windows up and the radio off when accelerating it sounds like darth vader is breathing behind the dash board through the vents. Its pretty loud and makes all sorts of weird and wonderful noises.
