Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Just wanted to know what remap do you have and how many mbar/Bar/psi does the car peak at. (with logs if you have) ko3 only owners with some stage one mods Just want to compare as mines only boost around 1860mbar (requested) and drops down. On my leon (early model- k03 - engine app) it boost at 2120mbar mid range.
If your talking boost pressure no idea what it is in mbar but according to my boost gauge it peaks at 1.40 bar which is about 20psi mods in my sig and on an AMD map...
and peak power is at just over 4.5k
Im waiting till my next days off as i want to play with the actuator a bit and try and get it peaking at 1.50 bar
Mines is no were near as that, do you have vag logs? :)
no havent got any logs yet ive got the free shareware version of vag-com so im not sure if i can run logs...if somone no if i can and what blocks to run i could have a go for you...be interesting to find out myself aswell.
mine peaks at 1.5 bar then tails of to hold a bar after 5k, depends on day to day though on a hot day mabey a little less than a 1.5 bar, this is with revo stage 1 forge fmic and a few other bits
hmmm,
why does everyone else peak so high?
Mine usually peaks about 18psi maybe 19psi (1.25 bar) then tails off to 13-14psi (appox 1 bar)
Thats on a JabbaSport Stage 1 Map
Code:
	Group A:	'003				Group B:	'115
		RPM	Mass Flow	Load	Ign. Timing		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME
MARKER	STAMP	 /min	 g/s	%	°	STAMP	 /min	%	 mbar	 mbar
	0.74	2440	51.61	100	9	0.34	2280	102.3	1940	1410
	1.66	2720	59.92	100	10.5	1.14	2560	110.5	1940	1530
	2.46	3000	70.22	100	12	2.06	2880	116.5	1940	1590
	3.25	3320	83.19	100	11.3	2.86	3160	127.1	1900	1690
	4.05	3640	91.92	100	12	3.65	3480	132.3	1860	1750
	4.85	3960	98.47	100	12.8	4.45	3800	130.8	1860	1770
	5.66	4280	107.31	100	13.5	5.25	4120	131.6	1870	1750
	6.46	4560	118.08	100	14.3	6.05	4400	133.8	1840	1760
	7.26	4840	125.81	100	15	6.85	4720	136.1	1850	1740
	8.06	5120	132.33	100	15.8	7.65	4960	136.8	1860	1750
	8.85	5360	136.06	100	12.8	8.46	5240	135.3	1840	1730
	9.65	5560	136.61	100	9.8	9.25	5440	132.3	1830	1710
	10.55	5760	140.64	100	14.3	10.15	5680	130.1	1830	1720
	11.46	5960	143.36	100	14.3	11.06	5880	127.1	1780	1690
	12.26	5760	8.33	9	1.5	11.86	6040	123.3	1740	1670
Mines requested boost feels quite low (ignore the actual boost for now) on amd map.
Custom Code stage 1....
used to boost to 24-26psi.... but since about march only got about 20-21psi.....
My stage 1 jabba peak at 19 psi but then drops really low to about 9 psi thats with fmic, bf cat back exhaust and jabbasport induction kit.
Mine is supposibly remapped to 190 by someone but only boosts to 10psi... So I don't believe it at all!!
It's ok though stage 2 coming my way :)
What are you running?
On my leon (early model) (app engine - with k03), Peaks to 1.4 on the motorway, but power delivery was nice, nice kick in the mid range.
Code:
		Idle speed	Air mass in	Throt Angle	Ignit Angle		Engine Speed	Engine Load	Spec. Boost	Actual Boost
	TIME	700-820 rpm	2.0-4.5 g/s	0.2-4.0%	0-12 BTDC	TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar
	0.37	2040	42.47	100	9	0	1880	89.5	2310	1250
	1.17	2400	58.61	100	7.5	0.77	2200	109	2310	1470
	1.97	2800	79.94	100	9.8	1.57	2560	128.6	2280	1730
	2.89	3320	123.53	100	5.3	2.39	3040	164.7	2270	2100
	3.78	3920	146.36	100	6	3.38	3680	191.7	2140	2450
	4.68	4480	157.33	100	6.8	4.28	4240	189.5	2120	2340
	5.51	4880	163.14	100	9	5.08	4680	182	2080	2200
	6.37	5280	167.89	100	9.8	5.97	5120	169.9	2030	2040
	7.19	5640	168.36	100	11.3	6.79	5480	163.2	1930	1940
	7.99	5920	169.86	100	11.3	7.59	5760	154.9	1850	1870
	8.88	6200	167.97	100	16.5	8.4	6040	146.6	1760	1800
	9.68	6440	168.56	100	17.3	9.28	6320	139.1	1700	1740
	10.48	6680	164.31	99.2	19.5	10.08	6600	133.8	1660	1690
Ideal mapping for a stage1 remap running the oem downpipe would be a peak of 18-19psi then aim for 14-15psi as long as the ko3 can higher up thre rpm range, then the low VE of the ko3 will cause the boost the tail of to around 10psi -8psi closer to the redline.
18psi peak and 14psi held with AFR of 12.5 will be good for 190+bhp 220lbft all day long, Trying to aim for higher boost when running to oem down pipe will cause heat build up and a AFR of 11.5 -11would been to help get the egts down but at a compromise to the power output.
Going to stage2 you will need to get the gasses flowing better, ie 3" down pipe, de-cat or sports cat. This will allow you to peak the boost at 22-23psi and aim for 16-17 psi help while still maintaining a AFR of 12.5 without getting the EGTs too high, The peak bhp from a stage2 remap will only be a few more peak bhp over a stage 1 due the the VE tail off being them same higher rpm, so 200bhp is about the MAX from a ko3. A stage 2 remap should return 240-250lbft and around 13bhp on the average bhp not the peak bhp.
Same with ko3s mapping aim for the load request to produce 18psi peak and 14psi held and it return 210bhp due to the better VE higher up the rpm range from the KOs
