RS6
Nov 24, 2009
1,110
I have a 2002 seat leon cupra r not had it long
checking the handbook today says it has alarm immobliser
so i thought i would test it on the drive way
i opened the drivers side electric window, and locked the car as normal
waited till at least a min for the flashing light on the door pin to go to a steady constant and then stuck my hand through the window expecting it to go off nothing? no alarm ring
i pressed the keyfob just once to lock the car am i doing something wrong does it not have sensors for this?
To test the alarm, lock the car with fob to arm the alarm. Wait a minute, then go and open the boot with the key. Alarm should go off.
If it does, it's just the voluetric interior sensors which sometimes come disabled from the factory. If you have VAGCOM, you can activate the sensors, and if not, but your anywhere near me, I can do it for you.
ah thanks lads thats of great help will give that ago then!
wish somebody lived closer to fareham with a vag com
btw i can't see any sensors attached on the pillars
Whats the proceedure for enabling volumetric sensors?
My alarm goes off if I open the boot but not if I throw my cat into the car...........I have VAGCOM, just can't find out how to do it....?
module 46 (central convenience)
advanced functions
10 adaption
recode =
channel 3 to 1 (default 0) autolock
channel 4 to 1 (default 0) +autolock
save and close
03 Auto Lock
04 Auto Unlock (keep 03 and 04 either both 0 or both 1)
05 Interior monitor
06 Unlock chirp
07 Lock chirp
08 Unlock indicator flash
09 Lock indicator flash
10 Alarm siren tone ( can be changed to UK, Asia, Germany, Other by entering 0,1,2 or 3)
: So 05 to 1, save and close.
Cheers Lee,
I did try that and the horn beeps when i arm the alarm, but was wondering about the alarm siren tone when it goes off (10 Alarm siren tone can be changed to UK, Asia, Germany, Other by entering 0,1,2 or 3) basically has my car got a siren and the horn or is it just the horn.
The thing is my mate's LCR has a siren alarm and mine is a horn.
Still got the standard alarm?
Just been searching seems the car horn is used for the alarm.:confused:
I have air horns on mine standard one was to weedy, i'll try it tomorrow to late now.
Actually scratch that mine "chirps" still when i lock it.
