It’ll be related to the battery being flat mate those are the first systems to shut down when battery voltage is low. You need a new battery and then to test for a drain to see why the battery went flat. It could just be that you don’t do any miles and over the years the amps have dropped or could be something else. Hope this helps.Yes it is start/stop and yes I do have error in start/stop message and the ACC and front assist error message also.
Sent from my SM-N770F using Tapatalk
It’s because your battery is flat... You need to replace the battery and then reset the errors and then retest for a battery drain.Nothing wrong I am putting in a boost gauge and a air/fuel ratio gauge, i done all the wiring to check it was all correct and when I finished I unplugged my new wiring to put it all back to normal as I need a o2 sensor fitted for the air/fuel gauge, and I put the fuse in incorrect hard to explain lol, I put the fuse in one right slot and one wrong slot basically.
And I think that is what drained the battery.
I'm not sure why the starter system faulty message is appearing though.
Why do I need to replace the battery? Did it not drain because of me putting the fuse in wrong?It’s because your battery is flat... You need to replace the battery and then reset the errors and then retest for a battery drain.
I will get it checked, its going in the garage Monday to have some parts fitted so I will get them to test it.That’s the reason you need to check for a drain with the battery voltage at what it should. You can try to recharge the battery if you have a charger. But you need to test the battery and see what condition it is as if it’s only at 50amps and should be 700amps it’s no good. You can have them tested at any battery fitting place for free.
My car is 2016 so the battery is 4 years old, i reckon it's the battery, well I'm hoping its simple like just the battery lol.How old is your battery? Just had to replace one in my Golf R after just over four years which is good going. Mine did similar errors to yours. Batteries don’t last forever unfortunately!
I must admit that I do find it annoying when someone posts about a problem they have and then don't follow up on whether they solved it!Hey,
Did you get this sorted? I've got the exact same issue. Sometimes I have to press the start button a few times to start or even stop the engine, then it says starter system faulty.
It also has drained the battery and caused the car alarm to go off.
