starting problem
rob_65
16
Just to follow up, here is a video of a warm start taken yesterday.
As I can't post links, navigate to any YouTube video and replace the watch?v=<BLAH> with GxoB4HpZAVw to view it.
Rob
Seatmann
Rough around the edges
Sep 16, 2010
5,568
9
Scotlanda
Check out "Hamman mod TDI warm start" Apparently it's a mod for the pd and warm starting problems, I haven't checked it out myself though but it's supposed to work.
spud31
Rail Zip User
Jul 14, 2011
407
the fuel temp sender on the head also gives similar symptoms to this when duff
mexicorich
Newbie
Apr 17, 2006
261
Hartlepool
Has this been solved?
My PD130 also became bad to start when hot
I'm reading up on the Hammand Mod to trick the ECU into a different map if the engine can't reach 280rpm when hot
has anyone tried this?
I was going to replace both my starter and battery but discovered that the connection from the solenoid into the starter casing wasn't as tight as it could be so nipped that up together with a new battery and finally after a year of poor hot starting it now zips over and fires straight away
