Steering column
j.cavo
8 valves of pure power
Aug 6, 2009
229
Liverpool
how easy is it to remove a steering column so i can replace a totally s*aged ignition as i dont thing it will come off
any help would be a life safer
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
once the switch gear and crap is out the way its a couple of shear bolts and a UJ bolt and it falls out more or less
:ignition:
:fixed:
:adjustable:
j.cavo
Aug 6, 2009
229
Liverpool
oh ok i see so u take the bolts out from the bracket on the adjuster the unbolt it at the bottom i want it complety intact as its a straight swap
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
u can leave the adjustable section all in one
in the last pic it's bolt #7 (shear bolt) that will be basically a dome so you'll need a centre punch or chisel to spin it round
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
comes off the top of the column once the switchgear is all out the way iirc
been a while sorry
j.cavo
Aug 6, 2009
229
Liverpool
ive got mine all striped back so its just the ignition so how do you remove section 3 (on top picture)
"sorry for being a little dumb"
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
in the side of the barrel there is a hole to push a pin in against a spring that will release the lock when you use the key
some of them didnt have one so you had to drill into it
if you email me ill send you the diagrams if ya like
j.cavo
Aug 6, 2009
229
Liverpool
mines been screwed to f*ck so i havent an idea if it would release i think i will go with the option of replacing it with the steering column save drilling or grinding anything off
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
usually only need to remove em when they dont work and then you need em working to remove em - fuzzy logic sadly
pics here if you need anything though
j.cavo
Aug 6, 2009
229
Liverpool
thanx m8
i will see how i get on but if i do need your help ill give you a shout
its just annoying because its been screwed the ignition wont snap back from the crank position and it stops the electrics from working
oh you know the spoiler on ur seat is that an f2 because am sure my 8v has the same 1
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ignition position and spring loading is determined by the switch in the rear (#5 in 1st pic)
without it the key just spins round and round
knock the lock assy off the top of the column
look under the switch for a small screw
remove/replace switch and refit
front bumper is a comet one (i think) and roof spoiler is F2 (original front self destructed)
j.cavo
Aug 6, 2009
229
Liverpool
it doesnt spin to infinty it just doesnt spring back from the starting position plus the casing around it (the metalic bit) is totally mashed as some thief has butcherd it with a screwdriver if that makes sense
my seat at the mo has a k&n kit on it and i think the exhaust is a magnex oval but am not to sure but it sounds quite mean im thinkng of puting a strut bar new hoses and some coloured Ht leads give it some what i good look
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ahh i get ya - sounds pretty mangled then, probably the damage making it stick
if it's been had a go at it's probably best changing the whole assembly anyway
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
part numbers suggest otherwise but i couldn't tell you the physical difference so worth a visual check
petrol and diesel strangely listed different also ? mmm
j.cavo
Aug 6, 2009
229
Liverpool
well ive got a polo and it looks the same so i am gong to see if it fits if not im guna have to be luck and find a bent seat on the same reg same model lol
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
let us know for sure, as said you can compare parts VAG wise all day for matching parts for sure but there may be such a small difference that it would be viable to look and check
