Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
mines been screwed to f*ck so i havent an idea if it would release i think i will go with the option of replacing it with the steering column save drilling or grinding anything off
ignition position and spring loading is determined by the switch in the rear (#5 in 1st pic)
without it the key just spins round and round
knock the lock assy off the top of the column
look under the switch for a small screw
remove/replace switch and refit
front bumper is a comet one (i think) and roof spoiler is F2 (original front self destructed)
it doesnt spin to infinty it just doesnt spring back from the starting position plus the casing around it (the metalic bit) is totally mashed as some thief has butcherd it with a screwdriver if that makes sense
my seat at the mo has a k&n kit on it and i think the exhaust is a magnex oval but am not to sure but it sounds quite mean im thinkng of puting a strut bar new hoses and some coloured Ht leads give it some what i good look
well ive got a polo and it looks the same so i am gong to see if it fits if not im guna have to be luck and find a bent seat on the same reg same model lol
let us know for sure, as said you can compare parts VAG wise all day for matching parts for sure but there may be such a small difference that it would be viable to look and check
