shotgunnoob
13
Nuneaton
I posted a little while ago about a tracking issue on my 2011 FR. When the vehicle is tracked straight, the wheel is off centre. It's been plugged it in and the angle sensor is showing 3 degrees out when the steering wheel is central.
My question is this.. If the rack has been separated from the column, which is likely if the clutch has been replaced, could it have been put back a spline or two out? I'm unsure of the setup and whether there is a key way only allowing fitment in one position.
Thanks!
